XL2 Eyepiece dropping at DVinfo.net
Old May 9th, 2006, 03:54 PM   #1
The eyepiece of my XL2 slowly drops to an impossible angle while filming.
Is there a tightening adjustment for this equipment?
I look forward to your thoughts.
Many thanks
chris
The red kite feeder
Chris Powell is offline   Reply With Quote
Old May 9th, 2006, 05:14 PM   #2
Images: 1
This has been an issue with the XL2 viewfinder. I take it your camera is fairly new? That's typically the cause. It's like they 'overlube' it from the factory and as it breaks-in, it tends to get a bit tighter and holds its position better. Try rotating it by hand for an extended period and see if it doesn't tighten up a bit.
Unfortunately, there is no friction adjustment for this.
-gb-
Old May 10th, 2006, 01:18 PM   #3
Thanks Greg.
The XL2 is pretty new and the sinking of the eyepiece is very frustrating, and was the cause of the loss of a unrepeatable shot today... I've long hankered after an FU-1000 and this has been the final push so the order has gone in this evening. The long wished for crisp focus should now be with my grasp - at least I'll not be able to blame the viewfinder anymore :-)
Cheers
Chris
The red kite feeder
Old May 10th, 2006, 01:25 PM   #4
Images: 1
Originally Posted by Chris Powell
Thanks Greg.
Cheers
Chris
You're going to love the FU-1000. As soon as possible, grab a manual lens to go with it and you'll be in focus heaven.
-gb-
Greg Boston is offline   Reply
