XL2 and EF Lens Adapter / EF Lenses / EOS Lens - Page 21 at DVinfo.net
Old June 15th, 2009, 03:25 PM   #301
You already have a great lens... just start shooting!
I currently do not own an XL2 so I can,t start shooting just yet.
Myself being 14 years old, I would have to work with my Dad for about 2 more years to purchase an XL2, so if I sold my 100-400mm lens I could get the XL2 much faster.
I guess I am thinking way to far ahead about getting another lens after I buy the XL2.
Thank you very much for your reply
CJ
Caleb Royer is offline   Reply With Quote
Old June 15th, 2009, 03:38 PM   #302
I wouldn't sell that lens if I were you.
Consider a used XL2 instead, our members usually have them for sale here.
Old June 15th, 2009, 08:19 PM   #303
That depends on how far away your wildlife are - and whether you want to consider a possibility of YOU being lunch for them :-). Seriously, if your wildlife are squirrels and birds - no big deal. However, I would be extremely cautious if they are polar bears or tigers. You get the point?
I have used MIRROR lens (SIGMA) of 500mm f/5.6 - custom-order on EF adaptor to take videos of eagles on a nest nearly 2km away - no problems.
Even used that lens with 2X Canon Teleconvertor with EF (7200mm equivalent) to video sherpas walking up to summit of Mt Everest from Base Camp in Rongbuk - about 23 km away in straight line distance.
Currently, for most decent wildlife, a 70-210 f/2.8 is more than good enough.
TingSern Wong is offline   Reply With Quote
Old June 16th, 2009, 01:56 PM   #304
Canon EF 70-300mm f/4.5-5.6 DO IS USM lens
Will the 70-300mm DO lens work well with the XL2 and EF adapter?
Is it a good quality lens?
When using the 70-300mm DO lens with the XL2 I wont need any lens support system because the 100-300mm DO only weighs 1.6lb and the standard lens with the XL2 weighs 1.4lb so that's only 0.2lb difference, I wont need to purchase a heavy duty tripod or lens support system.
Here is a review:
Canon EF 70-300mm f/4.5-5.6 DO IS USM Lens Review
THANKS,
CJ
Old June 16th, 2009, 08:23 PM   #305
I know nothing about your proposed use of your XL2 and the EF lenses. But, what I can tell you is - lightness has NOTHING to do with a need for a heavy tripod and good lens support. It is the MAGNIFICATION that is the cause of the "problem".
Even that 70-300 DO lens at 300mm is about 2,100mm when mounted on XL2 with EF converter. IS or no IS - if you don't have a "rock or concrete" anchor to mount that rig - please forget about using it. I am sorry - but I can't be any more blunt than this.
Consider this -
My Canon XL1 and 500mm f/5.6 mirror lens is about 2.5kg (extremely light) - even lighter than XL2 with 70-300 DO lens. The tripod and anchor system weighs 13kg - that should tell you the amount of stability required for such magnification.
Old June 17th, 2009, 06:27 AM   #306
Using any telephoto lens with the XL2 definitely requires a very stable tripod, preferably a pro-heavy duty tripod, but that doesn't mean that you should forget about using them.
I often use 300mm and 600mm ED-IF Nikkors for extreme-telephoto shooting and can obtain crisp and sharp footage. The most important factors are to use the correct tripods and techniques in the best conditions.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old August 10th, 2009, 06:55 PM   #307
How Large is EF Adapter???
I need to know how large the Canon EF adapter is so I can save some room in my Pelican case for when I purchase it.
CJ
Old August 11th, 2009, 12:32 AM   #308
EF Adapter dimensions
Measuring mine in it's black pouch it' approx:
3.5"H x 4.5"W x 2"D
Declan Smith is offline   Reply With Quote
Old August 11th, 2009, 06:03 AM   #309
Thanks for the dimensions.
Old August 20th, 2009, 07:16 PM   #310
EF-S to XL Adapter???
I own a Canon EF-S 60mm macro lens and XL2 so I was wondering if there is any such thing as an EF-S to XL adapter for my XL2.
CJ
Old August 20th, 2009, 08:50 PM   #311
Sorry, there is no such thing as an EF-S to XL adapter.
Old August 29th, 2009, 12:01 AM   #312
How Important is Image Stabilizer?
When using the XL2 with the EF adapter and a 300mm or 400mm lens how much does an IS help?, That is assuming you have solid legs and good head.
Thanks a lot,
CJ
Old August 29th, 2009, 10:34 AM   #313
300mm on XL2 is 2100mm. 400mm is 2800mm. Whatever help you can get (solid tripod + head) and IS as well is going to improve the image you take. It would also help if you place a sandbag on the camera (above the tripod) to minimise any shakes you would generate.
Old September 3rd, 2009, 06:42 PM   #314
About the EF-S to XL Adapter:
A few post back I asked if there was any such thing as an EF-S adapter for my EF-S 60mm f/2.8 lens to go with my XL2 and the answer was no, so I asked on another forum cold Wildeye and they also said no until someone posted this link: EF Adapter XL - Canon eStore
If you read over the compatible lenses carefully, you can see it has three EF-S lenses on the chart.
So know I'm a bit confused, could use some help.
Old September 4th, 2009, 02:36 PM   #315
Three EF-S lenses are listed on that page:
EF-S 10-22mm f/3.5-4.5 USM
EF-S 17-85mm f/4-5.6 IS USM
EF-S 60mm f/2.8 Macro USM
I have submitted a query into Canon USA about this to seek confirmation. However I would
not expect an answer back for several days since we're going into a major holiday weekend.
Chris Hurd is offline   Reply
