Editing 25p and PAL Frame Mode together... at DVinfo.net
Old July 21st, 2006, 10:31 AM   #1
If I would want to shoot with the XL1s PAL in Frame Mode (25p) and the real 25p of the XL2, can I just capture them in a normal project in a NLE (Premiere Pro or Magix) ? Or any other advice?
Mathieu Ghekiere is offline   Reply With Quote
Old July 22nd, 2006, 04:10 AM   #2
Nobody knows an answer?
Old July 22nd, 2006, 05:38 AM   #3
yes , you sure can . i do this with my xl2 and xm2 setup.
Mike Hardcastle is offline   Reply With Quote
Old July 22nd, 2006, 06:42 AM   #4
Thank you very much. So I just use normal settings within Premiere pro, or 25p settings?
Old July 22nd, 2006, 06:44 AM   #5
thats it mathieu, it senses the frame mode the same as the progreesive mode from the xl2.
Old July 22nd, 2006, 08:03 AM   #6
Thanks again,
best regards
Old August 8th, 2006, 06:32 AM   #7
hmm.. i know this is kind of an old thread and also my first post, but what settings would i use in the new project? and what settings do i use to capture?
btw, its a PAL XL2, footage shot in 16x9
Julz
Julian Seeto is offline   Reply With Quote
Old August 8th, 2006, 07:16 AM   #8
RED Code Chef
Frame mode is the same as 25p (if you are in a PAL country) to the computer.
So just set that for your project.
DV footage is copied over from the camera (tape) to your computer. You do
not need to set capture settings (except perhaps if you want it to split up
files at the points you pressed stop/start [if your software has that feature]
etc.)
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
