Wide angle converter at DVinfo.net
Old May 6th, 2007, 09:55 AM   #1
So... I found out that the century .7 converter doesn't fit the 20x lens for my XL2. Yeah, I missed the bit about it fitting the 16X lens.Does any one know if I can use it on the canon 3X lens?
Jon
Jon Goodman is offline   Reply With Quote
Old May 6th, 2007, 11:30 AM   #2
Hi Jon. Which converter do you have? The 0.7x has been able to fit the 20x lens for the past 2 years or so, but you should be able to tell from the converter's model number.
Richard
Richard Hunter is offline   Reply With Quote
Old May 7th, 2007, 04:06 AM   #3
It must be an older model, Richard. It's marked as Pro Dv .7X Wide Angle Converter. The glass on the rear element of the converter touches the front of the 20X lens.
Old May 7th, 2007, 09:56 AM   #4
Oh OK. That's bad news Jon.
