Would like to improve Workflow for filming concerts at DVinfo.net
Old July 10th, 2007, 01:45 AM   #1
Can anybody give me advice on how best to shoot a concert at my local music bar. I use 2 XL2's - one at the back and the other one I walk around with. I am particularly interested in how best to white balance both cameras. I usually leave the white balance to the indoor lighting preset - the reason for this is because of the variable lighting you get at concert venues - one second it's red, then blue...then white etc. I am not sure if this is the correct way to go but I figured that because of the various shades of white coming from the stage, then there would be no absolute white colour - I may be mistaken however. Anyway, any help and advice would be greatly appreciated. Thanks!
Ian Scanlan is offline   Reply With Quote
Old July 10th, 2007, 08:44 AM   #2
I'd probably just do a tungsten preset on both of them and be done with it.
Marco Leavitt is offline   Reply With Quote
Old July 10th, 2007, 01:15 PM   #3
I've been shooting a ton of this the past 2 months and I havent been able to nail down a perfect WB setting for this. After several tests I came to the conclusion that with all the fluctuating light and colors its best for me just to go with indoor tungsten preset and do any minor corrections in post. I used to balance before the show with the lights all the way up on a white card but found little difference from indoor preset.
Mike A
Mike Andrade is offline   Reply With Quote
Old July 11th, 2007, 04:12 AM   #4
Thanks Guys for the advice. I'll probably stick to the Tungsten preset myself. I think the nature of the lighting set up at most concert halls make it near impossible to access the 'optimum' camera setting. Where I film, I have to up the gain to around 12 - I know this is sacrilege to a lot of XL2 users. However, anything less and I can't see the band! It's just too dark.
Old July 12th, 2007, 11:51 AM   #5
Ian...
The other choice would be to have the lighting guy (or gal) throw a white stage light (not the house lights) onto the stage before the show. White balance to that and the other colors should come out correctly.
Jonathan
Jonathan Kirsch is offline   Reply
