Workstation for XLH1 at DVinfo.net
Old August 7th, 2007, 07:27 PM   #1
what is your workstation of choice? Mac or PC? What are the pros and cons of each? for editing 24f?
Brian Ladue is offline   Reply With Quote
Old August 8th, 2007, 07:21 AM   #2
Macs can run Premiere Avid and FCP...and you can use Bootcamp
to run Vegas, etc. so if you want something to do everything then
a MacPro, MacBook Pro, or the nice new iMac should work pretty
well.
Personally I really enjoy FCP and the new ProRes codec. It of course
works seamlessly with 24f.
The only con is the price of the hardware. However a stocked MacPro
is not much different than a similar Dell.
will griffith
producer/editor
Will Griffith is offline   Reply With Quote
Old August 8th, 2007, 01:34 PM   #3
I'm seriously considering getting a mac, though i've invested quite a bit into PC already....but i think because i'm going to need to upgrade both computer and Editor, i'm thinking about doing the switch..... i think it might be a good time...mainly because of Bootcamp allowing me to use alot of software that i have, and of course the new Final Cut Studio.....i've heard good things about it. My alternative is getting a new souped up Dell PC and upgrading Premiere to CS3 and getting Aspect HD, but i think the Mac might serve me well.....
oh yeah, and i don't much care for the new Vista OS, too many compatibility issues right now.
Old August 8th, 2007, 01:55 PM   #4
Will, what are you doing to monitor with FCP? what is the best way to do realtime monitoring? MXO? Second Display?
Old August 8th, 2007, 05:41 PM   #5
Check out this company.
http://polywell.com/us/index.asp
John DeLuca is offline   Reply With Quote
Old August 13th, 2007, 04:14 PM   #6
I have a PowerMac G5 and love it. I can't wait until my new Mac Pro comes in, it should be much more performant then the G5 in HDV.
Jonathan Selesu is offline   Reply With Quote
Old August 13th, 2007, 05:22 PM   #7
Running a dual core PC with Prospect 2K.
Prospect and 24F - ... I'm in PAL valley 25F ..... Simply the best investment
i have made in many years.
Herman Van Deventer is offline   Reply With Quote
Old August 16th, 2007, 03:10 PM   #8
Do you want to run SDI out of the H1? Are you capturing HDV to tape?
Chet
Chet Kenisell is offline   Reply With Quote
Old August 16th, 2007, 07:14 PM   #9
not really, just HDV to tape and a Firestore. But the option to do it is good!
Old August 17th, 2007, 06:30 AM   #10
Mac Pro -> Decklink HD -> HDLink -> Apple 23" LCD
Awesome.
Even when we are on location we lug the HDLink/Apple
Monitor combination around because it makes things real
easy. It fits snuggly in a rolling Pelican case.
No focus problems here. :)
will griffith
producer/editor
Old August 17th, 2007, 07:22 AM   #11
We do both. Effects shots are almost always captured HDSDI to
ProRes or similar. Makes keying things VERY easy.
The H1's HDV works well if shot and lit correctly.
We just ordered a Convergent Design's HDV to HDSDI converter.
We'll see how that helps us edit everything in something better
than HDV.
will griffith
producer/editor
Old August 17th, 2007, 08:39 AM   #12
Since you're only looking at HDV for now, you might think about a Dell 690 Workstation with a Matrox RT.X2. I've been looking at getting this for work.
If you think you might eventually want to capture HD-SDI straight from the camera or a deck, I would take a look at the Matrox AxioHD. I've seen both and they look good using Adobe Premiere, but I'm sure there are others out there. I haven't really done a very good job of comparing them. Especially value/dollar.
Chet
Old August 17th, 2007, 01:04 PM   #13
Awesome.
I like this setup....i'm leaning more and more towards the macs, and I'd likely in the future use the HD SDI.
Old August 26th, 2007, 07:12 AM   #14
...capture HD-SDI straight from the camera or a deck...
What deck are people using to capture -- be it SDI or otherwise?
Calvin Dean is offline   Reply With Quote
Old August 26th, 2007, 04:40 PM   #15
What deck for HDV / FireWire capture is Frequently Asked (answer: use a consumer Canon HDV camcorder).
What deck for SDI capture: you must use the XL H1 in VCR mode (as a deck) in order to capture from SDI. Alternatively, if you recorded to an external deck via SDI in the first place, then you use that deck for capture from SDI.
Chris Hurd is offline   Reply
