4 channel audio capture in Premiere CS4 at DVinfo.net
Old January 30th, 2009, 03:44 AM   #1
XLH1 - I recorded audio with 4CH. How do i capture all 4 Channels in Premiere CS4. It will seem to only allow me to capture 2 Channels. What's the trick here? I did a search about this as it seems it would be a common problem; but nothings showing up...
Tyson X
Tyson Persall is offline   Reply With Quote
Old January 31st, 2009, 11:32 AM   #2
Tyson, there's no way you can capture more than 2 channels through firewire, you have to recapture channel 3 and 4 in another pass AFAIK
There's however some add-on programs which do 4 channels like Scenanalyzer, but you have to do it "outside" Premiere CS4
- Per Johan
Old February 3rd, 2009, 07:19 PM   #3
Just a note::
Scenealyzer works and I have used it for quite sometime. However; The driver from scenalyzer interfers with my adobe drivers!!! That then makes direct capture with adobe products problematic for me!! I always captured with scenalyzer.
It is not an expensive program.
Perhaps someone else knows a quick fix but I do not..
It does work brilliantly for multi channels.
DATS ALL FOLKS
Dale W. Guthormsen
Old February 9th, 2009, 09:01 PM   #4
What else??
OK, so Scenalizer is the only program in existence to capture Channel 3 and 4? Come on theres got to be another way????
Tyson X
