Relay lens for XLH1 at DVinfo.net
Old November 11th, 2010, 03:32 PM   #1
Relay lens for XLH1
Does anyone know if there are any relay lenses available for the XLH1 series? (by that I mean a DOF adapter that attaches directly to the 1/3 mount without the use of the stock lens).
I know that P+S Technik make an XL adapter for the Mini 35, but that still seems massively expensive. I had read a long time ago that both Letus and Cinevate were working on XL adapters, but these seem to have come to nothing.
Is anyone aware of any other options than the Mini 35? I'm aware that this has been discussed previously (going back a couple of years though), and I was just wondering if there have been any developments in the meantime?
Simon Wood is offline   Reply With Quote
Old November 11th, 2010, 05:45 PM   #2
Unfortunately, it seems that the P+S Technik is the only option at this point. And the mini35 Compact, built specific for the camera, is by far the best option.
But at $7000 for the system, it is no small buy. It coast as much as the camera itself!
Michael Galvan is offline   Reply With Quote
Old November 12th, 2010, 07:23 AM   #3
I mentioned on another thread that there are pre-owned Mini35-400s on eBay and some may be XL1 and 2 versions which may fit up to the XLH1 if the lens mount is the same. It is recommended you check to see if the conductor pins inside the XLH1 mount stick out furthur than the XL1 or 2.
If these pins make contact with the metal rim of the mount, then the camera may end up cactus.
Listen to others who know better than I on this subject.
Old November 17th, 2010, 07:52 PM   #4
Yeah, seems the Mini 35 is still the only option...
Letus are offering a 1/3 relay lens ( Letus Corporation*::*Letus Relay Lenses*::*Letus 1/3" Pro Full Frame Relay Lens ) but the mount for the XLH1 has still to appear...
