How to get video out of a XLH1 to HDMI recorder at DVinfo.net
Old August 27th, 2021, 10:08 PM   #1
Hi All,
So I'm looking at getting a XLH1. I currently have a HDMI recorder. Is there a way to get video from the XLH1 to the HDMI recorder?
Looking at the XLH1 manual, there's a HD/DV terminal, looks like 4 pin firewire? But everything I'm reading, there's no way to get firewire to HDMI, they're different signals. And I don't recall a TV ever having a firewire input.
Am I missing something? Is the XLH1 not a good choice for a 'tapeless' camera?
Evan Platt is offline   Reply With Quote
Old August 27th, 2021, 10:38 PM   #2
Re: How to get video out of a XLH1 to HDMI recorder
Background: I have a canon xha1s. I used a Sony HVR-HD1000U that I got cheap with a HDMI portable recorder. So I'd record on the XHA1S (much better quality IMHO) then play back on the HVR as a deck. The deck on the XHA1s died :(
So my options are:
Find a place to repair the XHA1S deck.
Get a firewire recorder ($500 or so, then go tapeless on the XHA1S)
Or I found a REAL good deal on XLH1A with a monitor with SDI out. But bascally all I have is HDMI in.
So wondering what my best option here is :)
Old August 28th, 2021, 12:45 AM   #3
BNC Cable and the XLHI BNC connections. I used mine with a "Nanoflash" recorder.
Ron
Ronald Jackson is offline   Reply With Quote
Old August 28th, 2021, 08:07 AM   #4
Looks like that's not battery operated, right? Would love to be able to go tapeless. :)
Old August 28th, 2021, 12:47 PM   #5
This will convert SDI to HDMI. It runs on USB power, so one of those USB power banks would probably do the trick.
https://www.bhphotovideo.com/c/produ...2855/KBID/3801
Patrick Tracy is offline   Reply With Quote
Old May 22nd, 2022, 10:34 AM   #6
I just tried the following with the component output of a Canon VIXA HV40 HDV camcorder running live camera mode as a $21 solution..
"https://www.amazon.com/Component-Converter-YPBPR-Support-Player/dp/B07TYBLFYM/ref=sr_1_3?crid=JRGXET1CEDR2&keywords=component%2Bto%2Bhdmi%2Bconverter&qid=1653236465&sprefix=compo nent%2Bto%2Bhdmi%2Bconverter%2Caps%2C55&sr=8-3&th=1"
(Quotes added above to suppress the Amazon Logo.)
The converter was powered by an A/C USB power adapter and by a USB battery pack. Capture test was with a BMD Intensity Pro 4K card using Media Express. It worked reasonably well in a casual test and is a small package. However, cable/cord management is probably the biggest issue. However, this does not provide recorder control through the camcorder.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
