Nikkor lens adapter at DVinfo.net
Old February 21st, 2006, 01:29 PM   #1
Nikkor lens adapter
Recently I saw mention of someone (in N America I think) who produces an adapter for Nikkor 35mm lenses so you can use them on Canon XL camcorders. I want one that works similar to the Canon EF adapter (ie 7x magnification, though I realise I'll lose some of the electronic information).
Despite searching I can't find anything on them. Can anyone help with a link.
Paul Doherty is offline   Reply With Quote
Old February 21st, 2006, 01:56 PM   #2
Optex used to supply them (although they have now stopped trading) but some dealers should still have the Optex ones.
There are also a few USA dealers that make similar ones, although be careful, as some produce a plastic moulded one.
I use the higher quality version Nikkor to Canon XL mount made by Les Bosher (which is solid metal - but still cheaper than most other companies) Here is his url:
http://www.lesbosher.co.uk/default.htm
The one that you want is the XL1 mount shown in the bottom photo here:
If you order from Les, make sure that you let him know that you are using the XL-H1, as there are slight differences in the lens locking pin position between the earlier XL1, XL1s and XL2 mounts.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old February 21st, 2006, 02:53 PM   #3
Many thanks for that Tony. I have emailed Les - he was the man I was after, but whose details I'd lost.
