codec for keying at DVinfo.net
Old February 22nd, 2006, 04:07 PM   #1
codec for keying
I may be doing some green screen work in the future with the XL-H1. My question is what would be the best codec to capture to using the HD-SDI for the purposes of keying? The option for shooting on the HVX200 is there too, but is there a better compressed codec than DVCProHD for keying, that I could use the Canon for? I can't keep it in the uncompressed realm for storage reasons ... so what would be a suggested codec to convert to and work in Final Cut Pro?
Michael Galvan is offline   Reply With Quote
Old February 22nd, 2006, 05:54 PM   #2
I've never done keying, but I would think the Cineform 10bit 4:2:2 codec could work great.
Robert M Wright is offline   Reply With Quote
Old February 22nd, 2006, 10:10 PM   #3
Try Apple Intermediate Codec at a high bit rate or PhotoJPEG at 75% (4.2.2)
Barlow Elton is offline   Reply With Quote
Old February 23rd, 2006, 12:37 AM   #4
Originally Posted by Michael Galvan
...what would be the best codec to capture to using the HD-SDI for the purposes of keying? ... so what would be a suggested codec to convert to and work in Final Cut Pro?
Michael (disclosure - I'm from CineForm), Robert is right. 10-bit CineForm Intermediate keys very well, although currently it is available only on a PC - in case that is an option for you.
If you'd like a little more detail, we participated in an XL H1 test shoot and 35mm film print exercise a few weeks ago managed by Scott Billups. We recorded from the XL H1 HD-SDI output into a Wafian HR-1 directly into 10-bit CineForm Intermediate files from which the filmout was performed. I wrote about this exercise in the following blog: http://cineform.blogspot.com/. In the post from January 17, 2006, I also included a quote from Scott related to keying work he did on the CineForm Intermediate green screen material that was shot as part of the filmout exercise.
David Taylor is offline   Reply With Quote
Old February 24th, 2006, 12:25 AM   #5
same question using firewire
Which codec should I use for keying when grabbing the video via DV Rack and firewire?
Best,
Christopher
Christopher Glaeser is offline   Reply With Quote
Old February 24th, 2006, 01:10 AM   #6
Via DV Rack and firewire, you will get HDV (unless you have the camera shooting DV). HDV is what the camera will send.
Old February 24th, 2006, 11:15 AM   #7
OK, thanks. So, to get Cineform codec when capturing from the camera without additional conversion steps, I would use Aspect HDLink?
Best,
Christopher
Old February 24th, 2006, 12:59 PM   #8
I don't have Aspect, but yes, HD Link is CineForm's capture utility, that can be configured to convert to the CineForm codec while capturing.
Old February 24th, 2006, 04:03 PM   #9
Thanks guys ...
What are your thoughts on using something like the animation codec?
Old February 24th, 2006, 06:34 PM   #10
I don't know what the animation codec is. Is it something I should know about, but somehow managed to miss? (With a name like that, I would guess it to be something optimized for animated video, not video shot with a camera, so it wouldn't surprise me if I simply overlooked it.)
Old February 24th, 2006, 07:45 PM   #11
Starway Pictures
It's a Mac/Quicktime codec. Very similar to RAW or uncompressed. The bandwidth is too high for anything other than a RAID.
Robert Sanders is offline   Reply With Quote
Old February 24th, 2006, 07:51 PM   #12
Starway Pictures
Mr. Wright,
How's that Intel Mac support coming? ;-)
Old February 24th, 2006, 07:54 PM   #13
What tools will you be keying with?
Often, especially for an HD pipeline, it's easiest to work with individual image files per frame. So, shoot and capture with the best possible quality you have available (capture from the SDI to a 10 bit 4:2:2 codec), then render to TIFF or TGA files per frame for your visual effects pipeline.
This may sound cumbersome at first, but most visual effects applications tend to work best with image sequences rather than codec-wrapped video. And the 6 Megs per frame of a 1920x1080 TGA frame is half the size of what film guys are used to working with when handed Cineon plates. :)
Nick Jushchyshyn Matchmoving, Compositing, TD
imdb
Nick Jushchyshyn is offline   Reply
