-   Canon XL H Series HDV Camcorders (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/)
-   -   XLH1 Settings (https://www.dvinfo.net/forum/canon-xl-h-series-hdv-camcorders/71434-xlh1-settings.html)
David Walding July 13th, 2006 06:31 PM
XLH1 Settings
I am new to the XLH1. I have it and an XL1s. My vision is to shoot everything in 16:9 60i HD so that the Tape footage is always there and available to me in the future in HD. But for now, I will capture this and size it to 4:3 and SD, as to continue to use both in SD. If this is possible, are there any particular settings on the XLH1 to accomodate this best?? Be gentle, I am new to HD. Thanks.
Brian Critchlow July 14th, 2006 12:29 PM
Since you want HD archives, you need to shoot in HDV mode obviously. The viewfinder has an aspect framing mode, so you can shoot other aspects like panavision & so on.
I haven't gone deep into the manual on this feature, but you may be able to pull up a 4:3 frame in the viewfinder so you can position your subjects correctly, then its just a matter of cropping in post.
Hope this helps a little.
--edit--
one more thing, while surfing the manual, you can record in HDV, then do a down convert in the camera during capture/playback. This will definately help you in post.
also, after checking the manual, it does have a 4:3 aspect guide. Its in the display setup menu
Chris Hurd July 15th, 2006 12:29 PM
Brian has answered this pretty much exactly the same way I was going to.
There are two things to do:
First, when shooting, go to the Display Setup menu and choose Aspect Guide, set to 4:3.
Second, when capturing, go to the Signal Setup menu and choose HD Down-Conv, set to On.
That's basically all you need to do.
David Walding July 18th, 2006 01:20 PM
David
