Fujinon TV-Z lens on Canon XL1s? at DVinfo.net
Old March 18th, 2009, 06:58 PM   #1
I found a Fujinon lens from an eBay seller and they state it mounts and works correctly on a XL1/XL2 camera, just wondering if all "TV-Z" lenses will work or just this particular lens?
Thanks for your input!
C.M. Pritchett
Colin Pritchett is offline   Reply With Quote
Old March 18th, 2009, 08:22 PM   #2
Long ago there was a Fujinon 14x5.5mm that was converted to the XL mount by Optex UK. It was the *only* Fujinon conversion that I'm aware of. It has a 62mm front. Sorry I don't have easy access to the exact model number. See Guide to XL1 & XL1S Lens Options by The Watchdog
Be advised that *none* of the Z-series Fujis were ever converted to XL as far as I know. I'd disregard that auction if I were you.
Old March 18th, 2009, 08:39 PM   #3
Update:
that old XL conversion by Optex from 1998 was the Fujinon T14x5.5BRM4 and the focal length on that lens was 5.5mm to 77mm.
Picture attached. Hope this helps,
Chris Hurd is offline   Reply
