Wide Angle + Filters (Possible?) at DVinfo.net
Old September 19th, 2003, 02:10 PM   #1
I want to use my Century Wide Angle adapter
in conjunction with a couple of Tiffen screw-on filters - only problem is, the threading on the
WA Adapter is too shallow to thread onto the
lens with the filter(s) in place -
Anybody know of a jeri-rig and/or work
around for this?
Scott Moore is offline   Reply With Quote
Old September 19th, 2003, 02:49 PM   #2
Outer Circle
Your Century wide angle actually comes with filter threads on the front?
Old September 20th, 2003, 07:03 AM   #3
No...
NO - I want to be able to screw the filters onto my
XL1 lens AND THEN mount the WA adapter (72mm)
on top of the whole shootin match
Old September 20th, 2003, 02:43 PM   #4
Outer Circle
That's not a good idea. A matt box would be the better solution if your wide angle doesn't have filter threads on the front.
