sound on mini-disc at DVinfo.net
Old May 10th, 2002, 11:53 AM   #1
sound on mini-disc
Hey there people!
I am getting ready to film my first piece and I have to find an inexpensive way to do sound. Has anyone ever tried a mini disc recorder with a boom mike?
...all I need is a crumb!
Patrick Coker is offline   Reply With Quote
Old May 10th, 2002, 03:46 PM   #2
Should work. I've used them with stand mounted mics. Will fit in the sound person's shirt pocket - no need for a large fanny pack recorder.
Old May 10th, 2002, 04:09 PM   #3
thanks a lot Don. will let u know how it works out.
Old May 11th, 2002, 05:22 AM   #4
If buying a minidisc recorder, check to see whether or not it gives the recording controls; e.g., level adjustment while recording and a VU meter of sorts, that you need. Check www.minidisc.org for more than you ever wanted to know about MiniDiscs.
Old May 14th, 2002, 02:29 PM   #5
Doesn't Mini Disc employ pretty serious compression as compared to DAT or using the XL1 onboard. I wonder if that compression would pose a concern as far as quality at some point during post?
Ford Minton is offline   Reply With Quote
Old May 14th, 2002, 04:37 PM   #6
I don't know, I will have to check it out. I think I might just do both- thru the xl1s and mini disc, just in case.
Old May 14th, 2002, 07:42 PM   #7
Very few people can hear the differnce between a MiniDISC copy (at 5:1 compression) and a CD original - it takes a very golden ear. MiniDISC is based of 44.1 k sample rate (vise 48 kHz for DAT) and 16-bit sampling followed by the 5:1 compresion.
It MiniDisc not as good as DAT, but it is more than adequate for most video purposes, short of very serious, professional music recording in a studio environment. And it costs a lot less!
There are professional MiniDISC recorders available as well, at corresponding price points.
Old May 14th, 2002, 08:16 PM   #8
Do you know of a mike that works good with a mini disc recorder? this is for dialogue.
Old May 15th, 2002, 07:52 AM   #9
Boss Hog
Audio Technica has a model AT822 Stereo (One-point) mic that is terminated with an 1/8" mini plug. The mic is powered by a AA battery. I have used this mic with a small Sony minidisc recorder for capturing voice overs and other sound in the field. Note, that if you decide to extend the cable that comes with the mic by using a standard XLRM-XLRF mic cord, don't go beyond 20' as the output of the AT 822 is not balanced.
For my Marantz PD650 Professional Minidisc recorder (It has XLR mic inputs), I use an AT825 stereo mic. This one has a five pin XLR connector that fans out to 2 regular 3 pin XLR's. This mic can operate on phantom power or an internal AA battery.
Hope this helps.
"Film is Art; Theatre is Life; Television is Furniture!"
Steve Savanyu is offline   Reply With Quote
Old May 15th, 2002, 05:28 PM   #10
In addition to the AT-822, check the Sony ECM-MS957 single point stereo for around $200 or the 907 for a lot less (and not as good a mic). The AT may be the better mic overall.
Old May 16th, 2002, 10:10 PM   #11
So, I am using a Sony MZ-G750 mini disc recorder is that the best mike (the AT-822 )and is that recorder good enough or do I need to upgrade?
Old May 17th, 2002, 06:56 AM   #12
Boss Hog
I don't know which Sony model that is. The AT-822 will work with most any device that uses an 1/8" stereo mic input jack. (Including the XL1s)
A good mic will always improve audio quality.
Cheers
Old June 6th, 2002, 10:10 PM   #13
sort of a related question.
When using a DAT or a Minidisc, would one use a field mixer like a Wendt X2?
see:
http://www.wendtinc.net/x2specs.htm
Old June 7th, 2002, 06:44 AM   #14
Capt. Quirk
Many of you have already heard about my Korg. It is a 12 track hard disk recorder, with a built in mixer, and accepts 1/4" or xlr mics. It has a 4 gig hd, which will hold like 18 hrs on one track at 44khz quality. I feed all of my audio into it, and use it in most situations. It does require power, so have some cords ready.
However, it will NOT fit in a pocket.
Keith
K. Forman is offline   Reply With Quote
Old June 7th, 2002, 02:27 PM   #15
how big is the korg?
