A white point appears on all that I film at DVinfo.net
Old February 6th, 2004, 07:20 PM   #1
A white point appears on all that I film ...and I do not know if that is the lens or that comes from the case of the xl1s ?
I bought Xl1s kit in October 2003. brandnew!
Write me and I you will send an image with the white point !
segomil@ca.inter.net
daniel limoges
Daniel Limoges is offline   Reply With Quote
Old February 6th, 2004, 08:57 PM   #2
RED Code Chef
Did the "white point" just appear or has it been there since
day 1? Shoot me an e-mail with the picture at visuar@iname.com
and I'll put it on the web so everybody can see it.
Rob Lohman, visuar@iname.com
Old February 6th, 2004, 09:41 PM   #3
hi!
The white point appears everywhere I film ,has weak light and shutter 1/15 1/30... 1/60 seems to be ok!
f1.6 to 2.7 + -
the Xl1s are brandnew.
I cleaned the lenses many times, but nothing has to make,it seems that that comes from the interior of the case or the interior of the lenses!?
Old February 6th, 2004, 11:34 PM   #4
Moderator
Daniel,
Email me some pictures. I'll take a look at them.
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old February 7th, 2004, 12:23 AM   #5
Do a search for "hot pixel."
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old February 7th, 2004, 05:58 AM   #6
See the "About the CCD" note on the bottom of page 109 of the XL1s owners manual.
It states" Due to the construction of the CCD, in low-light recording using the slow shutter or gaining up, small specks of light may become visible in the viewfinder. In such cases, increase the shutter speed, reduce the gain or use an additional light source such as a video light."
A similar note is found on pge 71 of the XL1 manual.
The pixel appears to have a high 'dark current' tha becomes apparent in poor light situations where it is amplified by gain, or through long expsoure (sample) times.
If the camcorder is new (a few days from the dealer), you might be able to return it for another one.
And you may be able to mask the hot pixel in post production.
dpalomaki@dspalomaki.com
Old February 7th, 2004, 06:07 AM   #7
I believe the masking can be done in-camera with a firmware adjustment performed by the service center.
All the best,
Robert K S
Old February 7th, 2004, 07:23 AM   #8
....use an additional light source such as a video light....
Yes but ,when i films outside,that's has becomes difficult
Old February 7th, 2004, 10:37 PM   #9
Bad pixel...bad, bad pixel!
Hopefully, the white pixel you are seeing is only in the eyepiece. If the spot remains on screen when viewing it, then you porbably have a bad pixel in your CCD block.
If it is in the CCD, then I would send it back for repair. It's not fair that you have to correct every, single frame that you shoot! This includes work-arounds and cover-up such as adding more light, framing the bad spot into brighter areas or using software to correct the anomaly.
Personaly, when I buy a high-end piece of equipment, I don't expect it to screw up out of the box...I absolutely, positively, don't need any help screwing up...I can do that all by myself!
RB
"The future ain't what it used to be." Yogi Berra.
www.rbravo.com
Rick Bravo is offline   Reply With Quote
Old February 8th, 2004, 01:22 PM   #10
RED Code Chef
The pixel(s) is/are in the footage as well. I posted Daniel's
screenshot here.
Looks to me like a hot pixel which would need fixing at a Canon
repair centre. As Don pointed out low-light can also bring out
such issues. If it also happens during normal light levels it's
probably a hot pixel.
Old February 8th, 2004, 01:39 PM   #11
yES 'it also happens during normal light levels !
