-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   remote that controls autofocus (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/24418-remote-controls-autofocus.html)
Richard Klimesh April 11th, 2004 07:22 AM
Is there a remote zoom control that will also operate the autofocus on/off with the XL1s?
Ken Tanaka April 11th, 2004 12:49 PM
See the Varizoom VZ-Rock.
Edward Troxel April 11th, 2004 03:14 PM
That page says the "A" button doesn't work on the XL1S because the switch is a manual switch. It said it DID work on the GL2.
Richard Klimesh April 11th, 2004 05:28 PM
Yes, the reference to the manual focus switch on the XL1s is what prompted my question. What I want to do is leave the lens in Manual Focus and then remotely activate the Push AF button to auto focus from time to time. So, I'm looking for a remote zoom controller that will activate the Push AF feature. Anyone?
Ken Tanaka April 11th, 2004 10:48 PM
Richard (and Ed),
Sorry for the ambiguity in my article. The VZ-Rock's focus rocker will manipulate the 16xII auto lens' focus control when the lens is in Manual Focus mode. But, alas, it will not activate the Push Auto function. The Zoe also did not operate Push Auto.
I've never tried a Bogen/Manfrotto or a Canon controller.
Richard Klimesh April 12th, 2004 09:40 AM
Canon's description of their controller sounds like it will not operate the PUSH AF either. Hmmmm. I'm running out of controller options.
Jimmy McKenzie April 21st, 2004 09:27 AM
Excellent question! I have often wondered why Canon did not include this functionality built into the ZR1000. The focus in/out buttons on the remote are perfectly useless.
The trouble is that the "push a/f" button is mechanical acting upon an electronic switch inside the lens.
Once I recall seeing an xl1 where an exposed wire was siliconed to the lens switch and then crudely wired to the "photo" button next to the start stop button. What a great spot for this temporary focus override.
You might want to try that, but I would doubt you would have any warranty coverage remaining.
Richard Klimesh April 21st, 2004 10:36 AM
If I were more electronically confident and willing to forego the warranty I'd try that. So, apparently, there is no way to control the XL1s AF Push via a LANC? If so, that would make it a camera wiring issue, more than a controller issue, right? But if the AF Push IS able to be activated via LANC, why on earth hasn't a controller mfgr. added it to a controller? Geesh.
Norman Woo April 23rd, 2004 10:29 AM
That's what I have been searching for over the last few months for use on my Glidecam V16 stabilizer and found nothing. I'm also looking for a similar device that would "rack" aperture as well as I don't want to be touching the camera while it's in motion.
Norman Woo May 1st, 2004 01:34 PM
Folks
I found this LANC controller that is suppose to do "Push Auto" focus.
Any comments if this is true?
http://16x9inc.com/zoe/dvlanc.shtml
Ken Tanaka May 1st, 2004 01:41 PM
Norman,
See my review on the main section of DVInfo.
Richard Klimesh May 1st, 2004 07:31 PM
What a disappointment - to have the "push auto" work on the GL2 but not on the XL1S. I am bummed as it looks like I'm out of options. On the verge of just buying a Stealth and doing the manual "guess" focus.
Wayne Orr May 2nd, 2004 12:59 PM
The main reason you buy a zoom controller is, to control the zoom lens. Duh. So don't let a shortcoming in the lens design lead you to buy a lesser quality controller. There are better zoom controllers than the Stealth. Do a search here for some of the negative comments, so you have the info you need to make a sound purchase decision.
Richard Klimesh May 8th, 2004 11:27 AM
I thought you would find this exchange with the Zoe distributor:
TO: info@bebob.de
Are there any plans for a controller that will operate the "push focus" and "auto/manual" focus controls on the Canon XL1s? As far as I know there is not a controller on the market that will do this.
Best Regards,
Richard Klimesh
Dear Mister Klimesh,
Many thanks for your inquiry. Indeed there is no controller on the market allowing Push Auto and AutoFocus Remoting for the XL-1S.
The reason is that the camera can be fitted with different types of lenses. Some of these lenses doesn´t have a focus motor, so that Auto Focus and Push Auto doesn´t work. We think that for this reason, the camera doesn´t recognise the standard LanC Codes for Push Auto and Auto Focus. We think that the problem
would be that the camera tries for example to get the picture sharp, but the lens cannot do it. The camera software would then perhaps come into a loop, and you would have to reset the camera.
Sorry that I couldn´t give you some better news.
kind regards, Pierre Boudard
bebob
Ken Tanaka May 8th, 2004 11:50 AM
Thank you for sharing that, Richard. If Pierre says it, it is so. He's a very good authority on the matter.
As an aside, in the professional camera realm many remote controllers actually connect to the lens, not to the camera directly. That is, the lens hosts the control interpreter. As such, the lens actually runs the camera to a degree.
But that doesn't help us here. Well I guess someone's going to have to develop a special Push Auto remote controller that features an actuator that squeezes that button on the lens.
