Mini35 Test Images at DVinfo.net
Old June 24th, 2002, 05:07 PM   #1
Mini35 Test Images
I uploaded some shots onto my web site. These are from the test shoot I did on a feature I'm working on. I used a Pro Mist filter, hence the soft glow effect on the very white areas. Sunlight was bounced from of a 72'x72' silver refector. That was it.
http://www.monsterrocket.com/mini35/testimages/
I don't see many test images from the mini35. I'll officially make these public in a few days.
Some of the shots where handheld and I inadvertently switched off the mini35, hence you'll see very crisp black dots in the frame. When the unit is on, the dots disappear. Good thing this was a test shoot.
I'll probably just tape down all the switches on the adaptor to makes sure they don't turn off. Plus, I'll have the AC check the light, for EVERY shot, it will be a part of the camera "speed" call. In the future I hope P+S Technique make a more "durable" or "lockable" switch.
Let me know what you think.
justin
Filmmaker | Cinematographer
Justin Chin is offline   Reply With Quote
Old June 24th, 2002, 06:22 PM   #2
Doconomus
Justin:
Wow, the shots look cool! I'm impressed by the "shallow looking focus" or depth or whatever to it -- thats the best I can do to describe it. Doesn't look too video-like. Looking forward to seeing more shots. You're probably going to be having a bunch of people drool over this look and the mini35.
So, you only used available light and a reflector? It looks good with the sun looking like it was low in the sky.
Regards,
Kyle "Doc" Mitchell
Kyle "Doc" Mitchell is offline   Reply With Quote
Old June 24th, 2002, 11:49 PM   #3
The sun was behind a building casting a shadow onto the actors. The reflector was down the ally way reflecting the light down to them.
justin
Old June 25th, 2002, 03:07 AM   #4
RED Code Chef
Beautiful Justin, thanks for sharing!
Rob Lohman, visuar@iname.com
Old July 3rd, 2002, 03:44 AM   #5
ErikFilmcrew
Posts: n/a
What lens did you use, Justin?
I was thinking of getting myself a min35. The problem is that i can't afford a 35 lens on it. Are there any way of getting a lens with the same focus capabilities as a 35film lens for under 5000 dollars? Really, under 1500 dollars.... Can i get the same results with 35 mm still lenses? They can be cheap. The mini35 will cost me about 6000 dollars, right? and I also need some kind of adapter? What will the package cost me without a lens?
Thanks in advance Justin,
Regards,
Erik
Old July 11th, 2002, 12:39 AM   #6
It's going to cost you around $8200 for the adapter alone. Look for the prices at the ZGC website.
You can get the Nikon mount, and try the slr lenses, I haven't done that to say for sure.
justin
Old July 11th, 2002, 08:45 PM   #7
Justin, those images look awesome. Care to give me your adapter? :) I like the lighting and the shallow DoF is always pleasing to me with closish shots.
Cheers
Aaron
Aaron Koolen is offline   Reply With Quote
Old July 12th, 2002, 12:32 AM   #8
Thanks Aaron!
Here are some more shots from a short that I'm DP on:
http://www.firisproductions.com/aascreenshots/aass.htm
Extra points for the person who finds the hidden Junior.... ;)
justin
Old July 12th, 2002, 05:18 AM   #9
RED Code Chef
That is looking real nice again Justin.... damn
i found this:
marker 2:
http://www.firisproductions.com/aascreenshots/Picture-9.jpg
hidden:
http://www.firisproductions.com/aascreenshots/Picture-11.jpg
http://www.firisproductions.com/aascreenshots/Picture-28.jpg
Was this shot with the XL1s and min35 rig again?
Old July 12th, 2002, 05:47 AM   #10
Rob:
Yes, this was a mini35 shoot. There is no way that I'm shooting without this rig from now on. It never ceases to amaze me.
Still haven't found the Junior in one of the shots? ;)
Also, one of DVinfo.net readers is one of my AC's for this crew. So some props should go out to her.
Keep checking the link, since more shots will pop up as we continue.
justin
Old July 12th, 2002, 08:35 AM   #11
RED Code Chef
http://www.firisproductions.com/aascreenshots/Picture-16.jpg ?
otherwise I don't know.
Old July 12th, 2002, 04:23 PM   #12
Justin, what does the mini-35 offer apart from the shallower Depth of Field that we all know and love about film? Is this it's only + or are there others?
Cheers
Aaron
Old July 13th, 2002, 08:04 AM   #13
Aaron
In addition to a tighter depth of field, you get two more things. First, the focal length of these 35mm lenses is preserved. A lot of DP's are used to certain specific focal lengths from 35mm prime lenses. They'll choose a focal length based on setting, field of view and mood. They'll say, "I want a 28mm on this spot right here." The adapter lets them do that while still shooting on DV. It's the language of 35mm recorded on DV. The other thing is the quality of 35mm glass, it's preserved with the adapter. Video lenses just don't compare to cinematic glass. You should see what an image looks like through a Cooke or Arri lens. That's what the adapter lets you do.
Old July 13th, 2002, 09:08 AM   #14
You pretty much said it all Chris.
We've been doing some HD blowups from the XL1 and they look damn good. It's all in the glass. Good glass will make the XL1 as sharp as any 2/3" camera.
Overall the esthetic of the images are much more to my liking. The mini35 is worth every single penny I've spent on it. I find it the perfect camera for me and the way I like to work.
Rob:
You're going to have to work harder than that. For what it's worth Charles P. couldn't find the junior (2000w Light) either. ;)
justin
