Recording into the Canon XL? at DVinfo.net
Old September 27th, 2002, 03:06 PM   #1
I know that I can connect my Canon XL to my VCR and copy footage from my Canon XL to a VHS video tape.
My question is, can I do the reverse method of this? Can I copy footage from a video tape to a mini DV tape in the Canon XL? Basically, will the Canon XL record the footage from my VCR when both systems are connected?
Todd Dilley is offline   Reply With Quote
Old September 27th, 2002, 03:17 PM   #2
Sponsor: JET DV
Canon XL-1 - NO
Canon XL-1s - YES
Old September 27th, 2002, 04:52 PM   #3
See http://www.dvinfo.net/xl1faq.htm
Old September 27th, 2002, 09:09 PM   #4
Chris, I didn't see my question answered in the FAQ section.
Edward, I have the Canon XL1-s, so how do I accomplish recording into the camera from a video?
Thanks for your help guys
Old September 27th, 2002, 10:47 PM   #5
Hi Todd,
In your original post, you didn't specify which Canon XL you were referring to, the XL1 or the XL1S.
From my FAQ page at http://www.dvinfo.net/xl1faq.htm --
Q. How can I record analog video sources with an XL1?
A. It is not possible to record analog video sources with the XL1. The two analog video (RCA and S-Video) jacks on this camera are for output only.
You've since stated that you're referring to an XL1S. Analog video input is a feature on this camera. The procedure is outlined on pages 88 & 89 of the operator's manual. If you don't have it handy, you can download a PDF version from --
http://www.canondv.com/downloads/manuals.html
Hope this helps,
Old September 30th, 2002, 03:41 PM   #6
Just some advice when you do record footage from you VHS to your XL1s
Make sure your fire wire cable is not connected to your camera, (that is if you are using one)
Make sure you select audio 1 at your sound options, otherwise you will be recording the sound from your microphone when you transfer the footage.
Connect the sterio video cable with your video deck and camera at the RCA jacks, (on the back of your camera)
PSwitch to VCR mode, press record, Start your VHS and hit the play/pause button on your camera to start recording.
Its easy as that!... if you have an XL1s, the XL1 does not support this feature.
Good luck
Didi Schoeman
Didi Schoeman
ProAfrica
Television & Video Productions
Didi Schoeman is offline   Reply With Quote
Old October 9th, 2002, 06:29 PM   #7
Machinist Mate
I discovered AFTER buying my XL1 (not S) that it won't record from analog sources. So I bought a little Elura (could have been any model like a ZR or whatever) and now I have a neat little digital "VCR" that fits in my pocket, to say nothing of serving as a "stealthcam" when I can't get let in to places sporting my very conspicuous XL1, and even serving as a backup cam for the unexpected mishap* with the XL. The Elura is now my everyday capture device into my Mac (freeing up my XL and saving space on my desk).
* For instance, last week I made the mistake of trying to shoot outdoors in South Florida at 6:45 AM, after having the XL in my hotel room overnight. The camera misted up so badly in the humidity that every condensation alarm lit up, it was dripping off the lens and VF, and I wound up sending it back to Canon for an overhaul.
Lesson=Warm the camera up real well by running it on the power suppply overnight, then bring it outside (and keep it plugged in to power) an hour before the shoot to acclimate it to the warm moist outside air.
I ain't straight outta Compton, I'm straight out the trailer. Cuss like a sailor, drink like a Mc. My only words of wisdom are just, "Radio Edit."
Mike Butler is offline   Reply
