-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   XL1 power failure (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/7568-xl1-power-failure.html)
Bill DePalma March 9th, 2003 04:01 PM
XL1 power failure
I have an xl1 power problem. While shooting an event last evening I put the camera into standby mode for 10 min. afterwhich it failed to power back up. I have tried everything I know but it remains dead. Any suggestions? The camera has worked flawlessly for 3 years. There has been no indication that a power problem might pop up, just very suddenly it refused to come out of stanby mode. Thoughts?
thanks
Bill
Chris Hurd March 9th, 2003 04:21 PM
Try replacing the little time/date battery, a Panasonic CR2025 which you can pick up at WalMart in a package of three for $1.00. That might do it, might not. Worth a try. If that doesn't work, you're probably looking at a trip to Canon Service.
Bill DePalma March 9th, 2003 05:06 PM
Thanks Chris I will give that a try although the sudden nature of the problem without a low battery warning is a little strange. But I will give that a try. I will look into "the club" for service, it sounds very good.
thanks
Bill
Ken Tanaka March 9th, 2003 06:20 PM
I second Chris' recommendation. Just removing the backup battery for a few minutes and then inserting a new one may have a "reboot" effect on the camera's system.
It couldn't hoit!
Bill DePalma March 9th, 2003 06:35 PM
Thanks guys-
I tried the new battery but to no effect. It just seems so odd, I put the unit into stand-by and poof it goes into a coma. Oh well, hopefully I can get a quick turn around on the repair. Thanks for the input.
Bill
Don Palomaki March 9th, 2003 07:47 PM
Did you try turn the camcorder off with the power/wheel switch? Did you try a difernt power source? Maybe a fuse has blown.
Bill DePalma March 9th, 2003 09:37 PM
Originally I put the camera into stand-by mode but then was unable to bring it back to power. I have tried different batteries as well as ac connection. Nothing.
I'm puzzled, just have not seen this before. Maybe the stand-by switch has a short?
thanls
Bill
Chris Hurd March 10th, 2003 12:00 AM
Sounds like a job for Canon Service, unfortunately.
