sennheiser wireless to xl1s at DVinfo.net
Old February 8th, 2007, 11:55 AM   #1
Two questions:
1) which unit should I be purchasing for running the shotgun mich and wireless simoultaneously for the best outdoor audio?
2) will a beach tek dxa-4 work?
I have one here in the shop from my old vx1000 rig but the cannons are in georgia and I have to order before the weekend so i am ready to roll out on the 20th to film. Dont have a chance to test it before then.
Any setting adjustment reccomondations you can make would be apprieciated, i have read the factory settings on the sennheiser wireless may not be optimum.
John Coit is offline   Reply With Quote
Old February 8th, 2007, 12:00 PM   #2
I used the MA-200 and absolutely loved it! Not only did it give me 4 XLR inputs (I used two for the most part) it helped to counterweight the front heavy Camera.
It also has a mounting plate for mounting your reciever.
Also, make sure you have Mic furs/muffs for both your shotgun and Lav. THis is a MUST.
Commandment #11- "Thou shalt Render as thou goest."
"The fear of the Lord is the beginning of wisdom" (Prov. 1:7)
Bryon Akerman is offline   Reply With Quote
Old February 19th, 2007, 05:13 PM   #3
As far as I know, any XLR adapter that uses a stereo mini plug to connect to the XL1, XL1s, or XL2 front mic input will work. I certainly had no difficulty with a Sign Video XLR adapter, which is very close to the BeachTek products.
As far as the back audio inputs are concerned, I don't know. I've always used the MA 100 or 200.
Waldemar
Waldemar Winkler is offline   Reply With Quote
Old February 19th, 2007, 06:15 PM   #4
FWIW, I believe that the Sign Video products were previously marketed under the Studio One nameplate.
dpalomaki@dspalomaki.com
Old February 19th, 2007, 07:09 PM   #5
when using more than one mic i always us a portable mixer...and out put 1/4'' to rca and into the audio 2 on the xl1s. that way you have full control over both mic's and one isnt hotter than the other or somthing.
Michael Behr is offline   Reply
