-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   Lights, Camera ... darkness (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/89079-lights-camera-darkness.html)
Alex Sprinkle March 16th, 2007 09:40 AM
After shooting a wedding where they basically had the lights OFF during the reception (though they told me otherwise), I have come to the realization that I need some sort of lighting for the XL1s while I'm roaming.
Ideas? Experience? Do you know of any that are bad ideas?
Daniel Browning March 16th, 2007 10:30 AM
Easy. Just take the lens cap off.
Seriously, a 30W lightbulb will be enough for the A1 to get an exposure (with the right presets), but the TTL autofocus will not work well. If you can afford (and heft) the batteries, get one that's bright enough to use a big diffuser (at least the size of a human face). One advantage of having no lights is you don't have to worry about mixing light balance with room lights.
Don Palomaki March 17th, 2007 07:08 AM
I've used a MiniCool 2000 with a diffuser and a Sony HVL-20DW2 with success. Both at around 20 watts.
For most events like receptions, use the lowest watage you can get away with. No one likes to have a bright video light in their face at a party.
Waldemar Winkler March 30th, 2007 04:36 PM
When I can get away with it (always get B&G permission) I bring a couple of 700w Quartz flood lights and aim them at the ceiling or some kind of light reflecting surface to cast a significant, but gentle pool of light over specific areas I know will be important. I also place in the power line a dimmer. Very helpful. Important to this whole process is being able to position the lights in a safe and secure manner. Simply stated, if I can not position and secure a light fixture with absolute confidence no one could be injured should an accident happen I do not use it.
I always have a modified mini-cool 10 watt light on my camera. Modified with an 8" extension rod and a flip down diffusion gel. Having two or more fixed lights with my on camera light is an absolute pleasure. I can still acquire what I need with the on camera light.
