-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   CineForm and Sony Vegas 8 (https://www.dvinfo.net/forum/cineform-software-showcase/103609-cineform-sony-vegas-8-a.html)
David Newman September 21st, 2009 11:43 AM
Just your config as we add 64-bit support for Vegas several months ago, please contact support.
Jan Tervo December 30th, 2009 06:56 PM
Vegas Pro 9,
Hi All.
Do Vegas 9 finally support 10 bit io?
David Newman December 30th, 2009 07:09 PM
Pester Sony about that. :) Sony has the tools they need (SDK access), so we do hope it will happen in the near future.
Chris Wysocki March 5th, 2010 07:43 AM
Vegas PRO 8 crashing again!
Im running vegas pro 8.0 on windows 7 and when i render a 5 min. project using cineform codec it fails around 45 percent. I do have a trial version of BlueFX rack focus that is enabled in some of the media. Do you think thats the culprit till i buy the software? The trial isnt up until 3 days.
Can i get some suggestions that i can try in the vegas preferences settings that might help?
windows 7 64bit
vegas video pro 8.0 32bit
cineform hdv codec
pc is a core2 quad at 3.0
6 gigs of ddr2 ram
nvidia 8800 gts to dual monitors
EDIT: I got it working. i had in the project properties pixel format at 32-bit. I switched it to 8 bit and its rendered alot faster and stable.
Chris
Chris Wysocki March 5th, 2010 11:30 AM
Project settings question
My video footage was shot on a canon xh-a1 in 60i. Please let me know if my settings are ok or should i change something that will make the overall picture better. The ones with ? im not 100% sure if its the right setting. Thanks, Chris
Right now my project template is like this in the Project Properties:
Template: HDV 1080-60i (1440x1080 , 29.970fps)
Field Order: Upper Field First
Pixel Aspect Ratio: 1.3333
Frame Rate: 29.970 (NTSC)
Pixel Format: 8-bit
Full Res Render Quality: Best
Motion Blur Type: Gaussian ?
Deinterlacing Method: Interpolate Fields
Render to New Track Properties
Template: HDV 1080
Frame Rate: 29.970
Video Format: Cineform HD Codec V4.3.4
Interleave every .250 seconds ON ?
Create an Open DML AVi file ON
Cineform Settings
decode/encode 709hd ON
video format (Automatic) ?
Mark Watson June 14th, 2010 10:38 AM
Neoscene Applied to Existing Projects
I just took the leap and ordered Neoscene and was wondering if it's possible to improve Vegas Pro 8 projects I've already completed by converting my project media (HDV video) via Neoscene into .avi files and then reload the project and when Vegas says it can't find the file names (due to the extension change), just direct it to the new filenames.
Also, does the manual/help menu in Neoscene go into much detail?
Thanks.
Mark
