AE CS3 problems when Cineform Prospect 2k is installed... at DVinfo.net
CineForm Software Showcase
Old January 19th, 2008, 12:29 PM   #1
Win XP 32bit
AE 8.01
Prospect 2k v3.2.3 Build 152 demo
I can't even access Edit / Preferences dialogbox in an empty project, it gives me:
0::42
Microsoft visual c++ Runtime Error
After Effects warning: Unknown Exception.
AfterFX.exe - Unknow software exception (0x40000015) occured in the application at location 0x781346b4
If I uninstall Cineform it works perfectly.
If I Alt + TAB away from AE and back I always get the:
With Cineform installed, not otherwise.
Help?
/Jocke
Joacim Boive is offline   Reply With Quote
Old January 19th, 2008, 12:35 PM   #2
CTO, CineForm Inc.
Please submit a trouble ticket
www.cineform.com/support so the tech. support guys can look into it.
Old January 21st, 2008, 03:41 AM   #3
I did that, thanks!
Waiting for some feedback.
/Jocke
Old January 21st, 2008, 04:51 PM   #4
Still haven't heard anything back from the support...
But I managed to "solve" the problem myself, here's how:
Deinstall Cinform Prospect 2k
Install NEOPlayerV323b152-080116.zip
Now everything works perfectly in AE as well, no more error messages and everything works. Finally! =)
You do need to be finished with your captures though.
I'm still interested in why Prospect 2k isn't working properly, so I'll leave my support case open.
/J
Old January 30th, 2008, 01:23 PM   #5
The obvious problem with the above "solution" would be that you of course can't export to Cineform any more.
I've received another solution from Support that really made my day:
Go to the following folder:
c:\program files\cineform\prospect2k\
and delete the file called 'AJACaptureFilter.ax'
That should eliminate the problem.
Thanks to Jake Segraves it now works flawlessly! =)
/Jocke
Old March 2nd, 2008, 02:00 PM   #6
I was having the same problem with AE 7. Everytime I switched to another app AE would crash with a C++ Runtime error. Deleting the 'AJACaptureFilter.ax' file seems to have done the trick. I'm on WinXP with Prospect HD.
Tim Veal is offline   Reply
