Cineform crashes with Vista 64 Ultimate.
I just got a new laptop with four gig of RAM and Vista Ultimate 64 OS. Vegas runs beautifully on it with other codecs, but crashes regularly when I try to use any clip which uses the Cineform codec.
I know that Cineform recommends XP, but I need the 64 bit OS in order to access all of my RAM, and aside from this one issue, I really have no complaints with the new OS and actually find myself liking many of the new features. If push comes to shove, it is Cineform rather than Vista that will have to go, at least until this problem is worked out. |
submit a report at www.cineform.com/support it should not crash, I doubt it is Vista 64 related.
I submitted a report. I am really glad to hear that you think that the problem is something that might be fixable. As I look at other codecs, none of them seem to come close to being able to do what Cineform does: mainly function as a working codec that is for all practical purposes, as good quality as uncompressed.
On my ticket, the problem is now marked "resolved". I wish that it was. It looks like I must have checked some tab or something that changed the status but I sure didn't mean to. As I was typing, the interface was extremely slow and unresponsive and I would have to pause after typing the space after each word and wait for it to catch up.
Re-open if you can. Jake will be in later this morning.
You know, I'm looking at another Cineform project and it isn't crashing at all. I can't for the life of me figure out what is different though. I obviously have some more sleuthing to do.
I expected we might find something like that. Try importing the bad project into a new project. Try and determine if it is the project or the media.
The project that has been giving me problems the last couple of days now works perfectly. I did a media pool clean, but that shouldn't make much difference since it would only clean out unused files.
Earlier today I deleted the file AJACaptureFilter.ax from my Cineform directory but that didn't seem to help initially. Maybe it did make a difference after all. |
AJACaptureFilter.ax was definately the culprit. Not only does Cineform work now in Vegas, but a seemingly unrelated problem where Sony DVD Architect would crash before starting is also now fixed.
Just ran into the same problem again today after updating Cineform Neo HDV. Vegas started crashing again. Deleted the culprit "ajacapturefilter.ax" and I expect everything will be fine again.
Is it possible maybe to change the installer so that if you don't have the Aja card installed, it doesn't try to install this file? |
Well even with ajacapturefilter.ax removed, since the update I'm getting constant crashing.
My new super-computer only has XP32 and I was debating whether to get XP64 but was advised not to, since CS3 and maybe Cineform might not use the extra RAM anyway. Should I have gone with 64bit? |
| All times are GMT -6. The time now is 03:18 AM. |
