Cineform RAW encoding requirements at DVinfo.net
CineForm Software Showcase
Old January 23rd, 2008, 03:37 PM   #1
Hi,
Had a cursory look around but have't been able to pin down any real numbers.
I believe cineform RAW (for an HD sized frame at 24fps) is around 12MB/second? What CPU is needed to sustain that? Does it require any graphics hardware?
Many thanks in advance
paul
Paul Curtis is offline   Reply With Quote
Old January 23rd, 2008, 03:49 PM   #2
CTO, CineForm Inc.
For CineForm RAW alone, a single core of 2.33Ghz Core 2 Duo will do to (using both cores you will running between 40-50 fps.) The SI-2K uses a 2.33Ghz Core 2 Duo mobile for doing 2K @ 24p, but it is also doing some preprocessing (like fixed pattern nose removal.) No GPU is used by the CineForm RAW encoding engine.
