Cineform Or Blackmagic Intensity? at DVinfo.net
CineForm Software Showcase
Old March 10th, 2008, 08:55 AM   #1
Hi all,
I've not found an answer to this question elsewhere.
In principle both these solutions are similar right? They capture to their own codec for greatly reduced file sizes.
So, Cinemform talk about the resultant realtime performance in Premiere. Does this álso apply to the Blackmagic capture? Will I see similar benefits in editing speed. I'm not clear if Cineform offers a rendering advantage or not...
Thank you
Deniz Ahmet is offline   Reply With Quote
Old March 10th, 2008, 09:12 AM   #2
CTO, CineForm Inc.
The solutions are quite different. Blackmagic uses 8-bit M-JPEG (DCT based), CineForm developed a post-production codec from scratch for 10-12bit precision (Wavelet based), and much more performance. You can capture live from Blackmagic card to CineForm and the editing performance is high. Yet most choice CineForm for quality over performance. Note: We have yet to integrate Blackmagic for Premiere output -- working on that.
As your question -- "Cineform Or Blackmagic Intensity?" -- best answer is both.
Old March 11th, 2008, 01:24 PM   #3
As an amateur, the primary advantage that I see of blackmagic cards is that I can capture HDMI at a full 1090 rather than 1440 - but only if I capture live.
The blackmagic card may also remove a few idiosyncrasies with respect to windows failing to see a firewire device (yeah, that happens sometimes).
Cineform, regardless of what else you use, provides a better intermediate editing format. The stand alone version provides better compression than the standard version included with Vegas, which is why I use it.
Andrew Pitonyak is offline   Reply
