Cineform install woes at DVinfo.net
CineForm Software Showcase
Old April 18th, 2008, 11:58 AM   #1
Continuing to have Cineform installation problems. Now my CS3 XDCAM HD Presets are gone. Haven't heard from anyone in support now in nearly a week. Did everyone go to NAB--including support?
William Middleton is offline   Reply With Quote
Old April 18th, 2008, 12:04 PM   #2
I'm no expert but have you tried reinstalling Cineform, and cleared the registry?
Christopher Grant Harvey is offline   Reply With Quote
Old April 18th, 2008, 12:12 PM   #3
CTO, CineForm Inc.
Support is back. NAB is such a big event for us that even support was impacted.
The XDCAM HD presets are Adobe's, not CineForm's, so you might try Adobe support. I think those preset are new for PPro 3.2. However, as a CineForm user you should be selecting the CineForm/Prospect HD 1920x1080 preset at your frame rate.
Old April 18th, 2008, 01:08 PM   #4
That's the problem: the presets are not there in the new project window; only an empty cineform folder with no '+' sign to expand and view the presets. I already have a ticket open with support. They told me to run a .reg file that fixes the registry which I did but it didn't work. And now not only do I not have any cineform presets but the XDCam HD presets are now missing. I've already completely uninstalled AspectHD and CS3 and I still don't have my presets back. Definitely need some assistance here!
Old April 18th, 2008, 01:22 PM   #5
CTO, CineForm Inc.
These is where files should be
C:\Program Files\Adobe\Adobe Premiere Pro CS3\Settings\en_US\CineForm
With files like "Prospect HD 1920x1080 24p.prpreset"
and
C:\Program Files\Adobe\Adobe Premiere Pro CS3\Plug-ins\en_US\Editing Modes
Needs "CineForm Editing Modes.xml"
If they are both present, it might an Adobe issue. If there are missing then we can help.
Old April 18th, 2008, 01:54 PM   #6
Here is what is in the first folder:
CineForm 480p60 16x9 TS.vpr
CineForm 576p50 16x9 TS.vpr
CineForm 1920x1080 24p MPEG2-TS.vpr
CineForm DVHS 720p30 TS.vpr
CineForm WM9 720p30.vpr
There is no "CineForm Editing Modes.xml" file in the other folder. Is that something you could send me or attach?
Bill
Old April 18th, 2008, 01:59 PM   #7
CTO, CineForm Inc.
Your registry must be messed up for Premiere, causing our installer issues. Those .vpr files are years old, we don't use or install them any more. The attachement has the missing components, put them in the correct directories as shown above.
Old April 18th, 2008, 02:15 PM   #8
Great! That did it. Sorry to be a hassle about it all. I still don't have the XDCAM HD presets, but I think I the corresponding .xml file is missing for that too. I may have run cc cleaner one too many times.
According to the software, I'm on ApsectHD 5.0 (I installed from the DVD I purchased). When I first downloaded the trial version it was at v5.25. That may have been part of my problem.
Is there anything I need to be aware of when installing v5.25?
Old April 18th, 2008, 02:32 PM   #9
CTO, CineForm Inc.
Trailing newer software and then installing the old may have been a problem, but unlikely (I switch versions a lot.) The XDCAM xml is Adobe's not CineForm's so I can't send that to you. Attached are Aspect HD presets.
Old April 18th, 2008, 02:55 PM   #10
I had a problem when installing 110a which might be the cause of the missing files.
When doing the update, the uninstaller runs, but also the installer ran at the same time (ie without waiting for the unisntaller to finish). So when done I was missing HDlink and I assume some other files. I didn't check what else. But basically had to uninstall through control panel, then run installer. To avoid this.
Eric Larson is offline   Reply With Quote
Old May 3rd, 2008, 12:48 AM   #11
Hi there!
I've just installed Cineform Neo HD on my PC. The installation reported no errors and HDLink opens without any problems.
However, the editing modes seem to be missing from Premiere Pro CS3.2. I've tried uninstalling and then re-installing Neo HD but I still have the same problem.
There are no .prpreset files in C:\Program Files\Adobe\Adobe Premiere Pro CS3\Settings\en_US\CineForm
And "CineForm Editing Modes.xml" does not exist in
I guess my registry must be messed up too. If at all possible, please may I have the relevant files?
Jack Kelly is offline   Reply With Quote
Old May 3rd, 2008, 08:47 AM   #12
Jack,
If you want CineForm presets for PPro then you need to be using Prospect HD. Neo HD is mostly the same as Prospect HD but without our RT engine for PPro.
David Taylor is offline   Reply With Quote
Old May 3rd, 2008, 02:53 PM   #13
Ah, woops - my mistake. I see from the Cineform website that I can easily swap to Prospect HD.
Can I use this workflow with Neo :
1) Edit "off-line" in PPro using DV proxies
2) Picture lock
3) Conform in PPro
4) Import timeline into After Effects and grade using Color Finesse & AE's own tricks.
In other words: does Prospect HD give any benefits for AE? I assume not.
Jack
Old May 3rd, 2008, 04:54 PM   #14
CTO, CineForm Inc.
NEO HD and Prospect HD have the same features in AE. Prospect HD gets you online real-time editing within Premiere.
