New betas for all PC products. at DVinfo.net
CineForm Software Showcase
Old September 13th, 2008, 11:26 AM   #1
CTO, CineForm Inc.
NEO and Prospect versions 3.4.2.181
NEO HDV http://www.miscdata.com/cineform/NHDVb181.zip
NEO HD http://www.miscdata.com/cineform/NHDb181.zip
NEO 4K http://www.miscdata.com/cineform/N4Kb181.zip
Prospect HD http://www.miscdata.com/cineform/PHDb181.zip
Prospect 4K http://www.miscdata.com/cineform/P4Kb181.zip
Aspect HD 5.2.4.126
Aspect HD http://www.miscdata.com/cineform/AHDb126.zip
Many minor enhancement and fixes. A particularly valuable fix for Vegas users have a RGB level problem in the last release build.
Old September 13th, 2008, 08:13 PM   #2
David,
This is a follow up on my other posts. It turns out that there is still a problem with the Vegas build (current beta). It plays back fine now (RGB levels) but when you render any effects or transitions in Vegas it still drops to illegal levels for the length of the render.
I went back to the known working version (NEO-HDV-3.3.1.169) and it works fine. I unistalled/reinstalled (beta vs. older version) a couple of times to make sure. Now that I know about deleting the CFHD.dll this is not an urgent issue for me.
Thank you, Marc
Marc Salvatore is offline   Reply With Quote
Old September 15th, 2008, 09:29 AM   #3
CTO, CineForm Inc.
I refreshed all the download links, the beta(s) should now address all the Vegas issues you were having. You last encodes are also fine, just playback wrong in Vegas the previous download.
Old September 15th, 2008, 09:59 PM   #4
CTO, CineForm Inc.
Refresh HD and 4K releases as they had the wrong VfW codec (VirtualDun & Vegas) codec within them.
Old September 16th, 2008, 02:29 AM   #5
Hi David,
Do these work with Vegas 8.1?
I am thinking of upgrading to the 64 bit version and really the only plug in that's essential for me is Cinform.
Garrett
Old September 16th, 2008, 07:30 AM   #6
no they dont work...making 8.1 pointless imho
John Estcourt is offline   Reply With Quote
Old September 16th, 2008, 10:43 AM   #7
Just installed the NeoHDV 181 upate and now when I launch HDLink the splash screen says Aspect HD for Premiere Pro??? instead of NeoHDV. I am using Vegas 8.0c.
Also, i now get the following error (see attached) when I try to capture anything from my Sony HVR-M25U deck.
Thoughts?
PS. I am running Windows XP 64bit - SP2.
Nathan Mitchiner is offline   Reply With Quote
Old September 16th, 2008, 01:00 PM   #8
Why can't the Cylons just kill us already and stop teasing / torturing us with technology.
Dave Coyne is offline   Reply With Quote
Old September 16th, 2008, 02:29 PM   #9
Images: 10
....'cuz the cylons lost, eons ago, to the borg.
resistance is futile, you WILL be assimilated.
Old September 16th, 2008, 02:38 PM   #10
However the Daleks started it all. I should have known not to listen to a robot that doesn't have an "inside voice". You can't take those things anywhere.
Old September 18th, 2008, 12:18 AM   #11
Exterminate! Emergency Temporal Shift!
Seriously though, can you explain what it means on the website where it says cineform .m2t output removed for new users but not existing?
Marty Hudzik is offline   Reply With Quote
Old September 18th, 2008, 08:23 AM   #12
Due to a licensing problem that arose with our previous supplier of MPEG encoding, we needed to remove it from our new builds. HOWEVER, if you previously had AHD/PHD/P4K installed, the MPEG components are not removed during an uninstall, so the feature remains for those who purchased the product at the time we were shipping the feature.
David Taylor is offline   Reply With Quote
Old September 18th, 2008, 09:01 AM   #13
So if rebuilding amy PC it might be in my benefit to install the older build Of Aspect HD and then update it to the latest? Would that work? If you know what I mean. :)
Old September 18th, 2008, 09:12 AM   #14
Yes that would work. We will also keep an old archive copy for those who run into problems.
Old November 14th, 2008, 02:56 PM   #15
So what's going to happen when we upgrade to CS4 and the new Aspect/Prospect? Will this come back? Is this feature native to CS4 and will it remain functional via Premiere or are we out of luck if we need to go back to tape?
This is a pretty valuable output mode, not only for going back to tape but also for burning nice HD onto regular discs for the PS3. What's the new workflow?
Adam Gold is offline   Reply
