DVE Controls at DVinfo.net
CineForm Software Showcase
Old September 20th, 2008, 05:09 PM   #1
DVE Controls
Does anyone have a suggestion as to what DVE controls to use inside a Premire Pro 2.0 / Cineform project. The only filters that are showing up are my Matrox ones.
All I need to do is simply flip my frame 180 degrees.
-Dustin
Dustin Daniels is offline   Reply With Quote
Old September 20th, 2008, 05:13 PM   #2
Sorry, not 180 degrees, but the image needs to be flipped backwards.
-Dustin
Old September 20th, 2008, 09:04 PM   #3
CTO, CineForm Inc.
You should have CineForm DVEs if you have Aspect or Prospect installed.
Old September 20th, 2008, 09:55 PM   #4
Thanks David, where would I find them?
Old September 21st, 2008, 08:06 AM   #5
In the Video Effects
Listed under " Prospect/NEO " ( I use prospect, aspect would be listed for that version )
you should see "Horizontal flip" and "Vertical Flip"
If you want to rotate vs flip
Listed under " Cineform Pan,Zoom,Rotate " , again in the Video Effects
Old September 22nd, 2008, 06:31 AM   #6
Thanks Ray, I was looking under all the "CineForm Folders", not Aspect.
Man, do I love easy fixes.
Thanks again guys,
-Dustin
