Canon 5D and Vincent Laforet's Footage at DVinfo.net
CineForm Software Showcase
Old September 29th, 2008, 07:55 AM   #1
Vincent left 3 untouched videos from Canon 5D Mark II: The Helicopter Scene, The Kiss and The Sink Wake Up Spash.
I converted these files with HDLink using 24p to 23.396 in Prefs and it works but the Sound does not get converted. The files become native to my time line but they have no Audio track. I did not notice that before because the other files did not have audio. David any idea on that? Can you guys test it. They are aviable for donwload.
Mario Jesmanowicz is offline   Reply With Quote
Old September 29th, 2008, 09:56 AM   #2
Do you have Haali installed?
Pete Bauer
Old September 30th, 2008, 07:20 AM   #3
What is Haali?
Old September 30th, 2008, 07:37 AM   #4
AVCHD File Conversion
http://www.dvinfo.net/conf/cineform-...plitter-2.html
Please let us know if that resolves that problem.
Pete Bauer
Old September 30th, 2008, 05:30 PM   #5
No
I bought this CoreAVC Pro for $15 and nothing. When I uninstall ffdshow codec, the conversion stops working all together.
I get error mesage
"You are attempting to encode an image size for which this system is not licensed. When I put back the ffdshow it works
BTW I have HDLink /w purchase of Aspect HD
Old September 30th, 2008, 05:39 PM   #6
CTO, CineForm Inc.
That error does make sense. Canon is outputing an 1920x1080 image and Aspect HD is licensed to only 1440x1080 (as used by HDV.) We try and autodetect the 1920 to 1440 mismatch and scale for you, but that is not always working it seems. In the "Resize Video" select, set the output to 1440x1080 and try your conversions again.
Old September 30th, 2008, 07:09 PM   #7
I thought something like that was possible that is why I mentioned that I have Aspect which only does it to 1440x1080 but then why was ffdshow working without that resizing?
ANyway I did what you said and at 1440x1080 it created the files but there is still no audio
Old September 30th, 2008, 08:24 PM   #8
CTO, CineForm Inc.
Download and install the AC3Filter from Free-Codecs.com :: Download AC3 Filter 1.51a : AC3 Filter is a DirectShow filter for AC3 decoding to fix your audio.
Old October 1st, 2008, 03:32 PM   #9
Did that still no audio
Old October 1st, 2008, 03:37 PM   #10
CTO, CineForm Inc.
Use GraphEdit to determine why your PC is using the wrong audio filter.
Old October 1st, 2008, 08:59 PM   #11
When I look at the avi file created with GraphEdit
I get:
file.avi -> avi splitter stream 00 -> Cinefrom HD Decoder 2 -> VMR Input Video Renderer
Old October 1st, 2008, 09:00 PM   #12
there is no second stream for audio like ac3 filter
Old October 1st, 2008, 09:04 PM   #13
CTO, CineForm Inc.
The problem not with the AVI, the problem is the decoding of the MOV source. If the source "graph" doesn't provide a convertable audio output the AVI will be silent as you have found. Throw your source into GraphEdit, that will be more revealing.
Old October 2nd, 2008, 03:02 AM   #14
interesting:
mov -> nero mp4 splitter -> y Page -> Video Renderer that is all
Old October 2nd, 2008, 03:10 PM   #15
David, the AC3 filter is not usable in the 5D case, because the 5D is not an AVCHD camera, it uses it's own version of h.264 and uncompressed audio. From what I have seen so far, only users who have NERO installed can use that footage with HDLink. CoreAVC and a bunch of other apps won't help much.
Eugenia Loli-Queru is offline   Reply
