1440 vs. 1920 at DVinfo.net
CineForm Software Showcase
Old January 29th, 2009, 11:11 PM   #1
1440 vs. 1920
Just upgraded to Prospect, and maybe this feature was in Aspect but I didn't notice it: I can convert from 1440 to 1920 upon capture.
So, does it make a difference? Does it matter whether I set up a 1920 project and convert all 1440 upon capture, or just do what I used to do: a 1440 project at 1.33?
Couldn't find any recommendations on the Cineform site about this.
Old January 30th, 2009, 01:09 AM   #2
I wouldn't bother unless you are mixing 1920x1080 and 1440x1080 footage. The 1920x1080 makes sense if you have a 1920x1080 camera, but interpolating your raw footage won't look any better than interpolating to those dimensions for your final render if you want a little extra resolution for your titles and graphics.
Laurence Kingston is offline   Reply With Quote
Old January 30th, 2009, 01:12 AM   #3
That's what I thought, but just wasn't sure. Appreciate the help.
Old January 30th, 2009, 01:43 AM   #4
More info / feedback -
Robert Young's Answer - Thread - http://www.dvinfo.net/conf/cineform-...ls-hdlink.html
Herman Van Deventer is offline   Reply With Quote
Old January 30th, 2009, 02:07 AM   #5
So it looks like you could go either way and it won't make a huge difference, especially with HDV.
Old February 2nd, 2009, 12:59 PM   #6
I'm still impressed with 1920 sq pix with regard to direct transcode to other formats (DVD, BR, Flash, etc.), so I bring everything into a project as 1920x1080. I can output whatever delivery format I need directly from the CF 1920 timeline with AME or Procoder and get excellent image quality.
This represents a huge simplification and time savings over my prior 1440 workflow.
Bob
Old February 2nd, 2009, 01:16 PM   #7
Hm. Might be worth an experiment. Thanks for the input.
Old February 2nd, 2009, 01:43 PM   #8
One difference: on my Q6600 capturing/converting HDV to CFHD in it's native 1440x1080 happens realtime. Capturing/converting/resizing takes quite a bit longer so I end up sitting drinking too much coffee at times.
And no, it wasn't a feature offered in AspectHD (as its resolution limit was 1440x1080).
Old February 2nd, 2009, 04:30 PM   #9
Another good use to up-convert is when you want to create 720 footage with pan's and such... you bring in the 1920x1080 and you can pan,crop,crawl... then output the completed scene at 720...
Ray Bell is offline   Reply
