real time engine update? - Page 2 at DVinfo.net
CineForm Software Showcase
Old August 5th, 2009, 06:14 AM   #16
CTO, CineForm Inc.
Originally Posted by Matt Vanecek View Post
Where is the 32-bit control in Prospect HD? The Prospect HD manual is still for Aspect 5/Prospect 3. I don't see anything in the Media Exporter dialog that looks relevant.
Matt
In CS3 it is in CineForm's Playback Setting control panel.
Old August 5th, 2009, 05:46 PM   #17
Should I understand that to mean that the setting is not available in CS4? I don't have CS3...
Matt
Matt Vanecek is offline   Reply With Quote
Old August 6th, 2009, 09:13 PM   #18
Quick question: will the RTE be used also for the Multi-Camera recording window?
Matt
Old August 6th, 2009, 09:43 PM   #19
CTO, CineForm Inc.
No, wasn't in CS3 either. The multicam feature is not exposed for third party implementation, so you are stuck with the Adobe version.
Old August 7th, 2009, 04:46 PM   #20
crap. crapcrapcrap. The 4.1 Multi-Camera recorder is crap. The 4.0.1 Multi-Camera worked great. Others have noticed the difference. I was praying that the RTE would also work with the Multi-camera recorder. crap. that really sucks. @$*!)^% Adobe! and their support is NO help whatsoever! They've had that ticket for 2 months now. :(
Oh, well, I'll find a way to struggle on through....
Matt
Old August 7th, 2009, 05:42 PM   #21
Yes, this is very disappointing. It never even occurred to me that this wasn't supported by Cineform, even though I never noticed any improvement with this over using non-Cineform presets in CS3, speed-wise or qualtiy-wise.
Seems like everything that's important to me, isn't for Cineform.
Old August 7th, 2009, 05:50 PM   #22
David, This thread brings up a question that I have had for a while now and just have not
asked it...
so here it is... when I turn on display filter stack why do I have to turn it on each time
I start Premiere... shouldn't the setting be a sticky type of selection??
and a second question... what are the rules for Cineform in respect to 8,16,32 bit...
I have the selection selected for 32 bit and I can see the 32bit is being implemented...
but what are the rules that Cineform uses to get the 32bit out..
Old August 7th, 2009, 06:23 PM   #23
CTO, CineForm Inc.
Display filter stack should be sticky, I haven't seen it not working -- report if it is not sticking in a new project to support. We do 32-bit float pretty well, such that you can see your HDR work on the timelise, is seems the Premiere edit modes don't work this well, i.e. CS4 doesn't display 32-bit filters correctly in my opinion (they render correctly though) -- we will fix that with our play module.
Old August 12th, 2009, 07:09 AM   #24
David, You mentioned that your realtime engine can render 5 times faster than adobe feeds the data to it, thus adobe is the bottleneck here. Since I have been playing with CS4 I have noticed that it takes 3-4 times as long as CS3 to render same projects. Is this just a giant "oops" on Adobe's part to release a new version of software and accidentally cripple the rendering component? I actually like working in CS4 but hate the super exaggerated render times....even with non cineform related projects.
Thanks for any input.
Marty Hudzik is offline   Reply
