First Light question/noise removal at DVinfo.net
CineForm Software Showcase
Old August 2nd, 2009, 06:26 AM   #1
Using First light is there certin setting that can be used to remove grain from video shot in low light such as a wedding reception? I know the noise is in the color channels but which channels should I start with to reduce the gain/noise if its possible. I know receptions are not perfect because they trun the lights way down and I do use an on camera light but very spearingly not to be intrusive.
Thanks.
Bruce Gruber is offline   Reply With Quote
Old August 2nd, 2009, 09:05 AM   #2
CTO, CineForm Inc.
Noise reduction is not a filter within First Light, although you can reduce the perceived noise through color correction.
