DVD problem in PremPro from AspectHD at DVinfo.net
CineForm Software Showcase
Old March 12th, 2005, 11:55 PM   #1
Hi,
I'm new here and these forums are very informative. Thanks!
I'm using a Sony FX-1, Premiere Pro 1.51 and Aspect HD 3.0. When I render a mpeg 2 for DVD from Adobe Media Encoder, pans don't look smooth. I've tried upper field first, lower field first and progressive but nothing helps. It almost looks like a much lower frame rate. I'm shooting 60i. If I render the Cineform HD timeline to m2t and export it to the camera, everything looks great. If I downconvert in the camera and render a DVD from the DV timeline the motion is smooth. It seems to me that there is a problem in scaling. Has anyone seen this or have any suggestions? BTW Aspect HD 3.0 is AMAZING.
Thanks, Mick
Mick Guzauski is offline   Reply With Quote
Old March 15th, 2005, 01:10 AM   #2
what are your export settings when going out to DVD?
Michael Stewart is offline   Reply With Quote
Old March 15th, 2005, 09:50 PM   #3
Hi,
I tried several settings. I ended up with 8Mb/s 2pass VBR / Quality 5 / 8 n frames / 2 b frames / upper field first. The strange thing is that if I render the timeline to m2t, then record it back to the camera and then re-capture it as SD DV, I can make a DVD with no motion problems but of course the color and clarity doesn't look as good.
thanks, Mick
