Cf raw qt 24p to 23.98p at DVinfo.net
CineForm Software Showcase
Old September 21st, 2009, 09:46 PM   #1
I have a projet recorded 1 day in 1080p24 and the 2nd day in 1080p23.98 in si2k.
Could i remaster the 24p files to 23.98?
This function is not enabled at least in my remaster version.
Thanks in advance.
Also i want to report a bug.
usign compressor droplet i dont have timecode in the prores rushes.
if i process this trough FC batch export i have TC.
QT only read TC at first frame then nothing.
FC read timecode all the time
thanks in advance.
sebastian toro
Sebastian Toro is offline   Reply With Quote
Old September 21st, 2009, 10:08 PM   #2
CTO, CineForm Inc.
Re-interpret your footage or change the frame rate is the header, either technique bypasses the need for complete new footage through Remaster.
Report bugs to support, as the appropriate engineers can't always read here.
Old September 22nd, 2009, 08:29 PM   #3
Header
Thank you David o will report to support regarding his bug.
Where can i found info regarding the modification of the header and the posibilities to manipulate this. Is there any good resource there for learning this kindergarten of Stuff?
Thanks in advance
Best!
Sebastian toro
Old September 22nd, 2009, 08:55 PM   #4
CTO, CineForm Inc.
These tools should help:
QuickTime Tools
