ETA On Cineform Realtime CS4 Engine at DVinfo.net
CineForm Software Showcase
Old October 26th, 2009, 01:40 PM   #1
Hello,
What is the ETA on the real-time engine being ready for Prospect Cineform 4 under Premiere pro cs4?
Also is Windows 7 fully supported yet with Cineform?
Leo
Leo Baker is offline   Reply With Quote
Old October 26th, 2009, 03:49 PM   #2
I think this is the latest status (don't know if you have seen it already or not):
http://techblog.cineform.com/?p=2534
Expect to see the Prospect RT engine rollout with the feature additions mentioned below. Dates are estimates and may change.
o CineForm project presets (Sep 18). This eliminates use of the desktop mode and also eliminates the need to use MPEG as a render-to format for previews.
o CineForm (Real Time) Play Module first release (Oct 23). This is the underpinning of the RT engine. The first release will not support HD-SDI monitoring
o Full RT engine with HD-SDI support (Nov 6)
Sorry - can't help you with the Windows 7 bit.
Matthew Longbottom is offline   Reply With Quote
Old October 26th, 2009, 06:07 PM   #3
PHD4 seems to work fine with CS4 in Windows 7 .
(With CS3 and Windows 7, timeline playback requires a workaround: http://www.dvinfo.net/forum/1436379-post10.html )
Old October 27th, 2009, 04:40 AM   #4
Hmmm I might look to upgrade when this is released - Should make things quicker this end!
David Dwyer is offline   Reply
