last second of audio missing after neoscene transcode at DVinfo.net
CineForm Software Showcase
Old March 30th, 2010, 07:45 PM   #1
am transcoding from canon 550d to neoscene high quality avi, many of the avis have lost the last bit of sound, but it's there on the original footage - does anyone know a fix for this? thanks
Ade Towell is offline   Reply With Quote
Old March 30th, 2010, 09:42 PM   #2
CTO, CineForm Inc.
The sound has not been lost, it just doesn't get improved into CS4. That has been fixed internally. If the audio you need from the end, load the original audio from the MOV or use VirtualDub to export a WAV.
Old March 31st, 2010, 04:06 AM   #3
ok thanks, its not that crucial for most clips but a bit of a work around, didn't realise this was normal
Old March 31st, 2010, 03:09 PM   #4
Last Second of Audio Missing from Canon 5D mk II Too
I'm also having the same problem...
Canon 5D mk II (firmware 2.0.4) 30 fps (IE. 29.97 fps) MOV files which are transcoded by NeoScene v1.6.0.140 lose the last one second of audio. This did not happen with NeoScene when the Canon MOVs were 30fps.
I'm using Premier Pro CS3.
Will this be fixed in a NeoScene update?
Julian Frost is offline   Reply With Quote
Old March 31st, 2010, 04:37 PM   #5
CTO, CineForm Inc.
Maybe. It is a different issue as you are talking about CS3, the fix was in CS4.
Old April 1st, 2010, 08:38 AM   #6
Quote: The sound has not been lost, it just doesn't get improved into CS4. That has been fixed internally.
David, can you clarify - are you saying it was fixed by Adobe, or by Cineform?
I still have this issue with CFHD's converted from avchd from two different cameras (HMC40 and Canon HF10) and I have the latest updates that I'm aware of (Prospect 430b240 and CS4.2.1).
Old April 1st, 2010, 09:28 AM   #7
CTO, CineForm Inc.
Fixed by CineForm, it has not been released yet.
Old April 1st, 2010, 09:36 AM   #8
Good news - thanks!
