Field order at DVinfo.net
CineForm Software Showcase
Old April 10th, 2010, 06:18 AM   #1
Field order
Is there a tool (beside the Bridge)that can read the field order of a Cineform avi. Gspot can't.
I have this weird 'issue'.
I capture a hdv tape with NeoScene. As hdv is upper i assume the CF avi is also upper.
Drop it in CS4 on a upper field timeline (hdv 1080i25).
When i export the timeline as a Cineform avi i choose upper in the AME, the avi I end up with has the fields all wrong.
When i export with LFF it all looks just fine.
So is CS4 interpreting the footage all wrong or what....
Old April 10th, 2010, 11:10 AM   #2
Mediainfo? MediaInfo
Old April 10th, 2010, 12:07 PM   #3
Thanks but i does not read fields at all.
Old April 10th, 2010, 12:17 PM   #4
Yes, based on the non-info in the CF files. I have seen the opposite as well, that 720p50 interprets as field based footage in Pr and Ae.
Use Interpret Footage and set CF 1080i files to Upper Field First. :)
/Roger
Roger Averdahl is offline   Reply With Quote
Old April 10th, 2010, 02:20 PM   #5
Hey Roger fancy seeing you here. :-)
CS4 interpretes the footage as upper, so far so good
Its when i export to upper, the CF avi does not look right. I have to export to lower.
Old April 10th, 2010, 03:30 PM   #6
Thanks Ann! :)
Thats strange, where are you viewing the exported file, on computer or television? Are you exporting to SD or HD?
/Roger
Old April 10th, 2010, 06:18 PM   #7
To inspect field order, I use a Virtualdub plugin called ViewFields:
ViewFields: This filter is nearly identical to the unfold fields option within VirtualDub's built-in deinterlace filter except that it re-arranges the top field on the top and the bottom field on the bottom of a frame.
http://www.geocities.com/siwalters_uk/viewfields.html
Old April 11th, 2010, 12:17 PM   #8
Thanks Graham i will have go at it.
Roger: i am viewing on a pc but when i convert it to mpeg2-dvd with the same fieldorder burn it to dvd and play it on the pc or a regular tv with a standalone it is still wrong.
Old April 20th, 2010, 03:34 AM   #9
Hi Ann -
I have the same workflow and have just encountered the same problem. I had to export with LFF. I haven't had time to investigate this more. Have you had any success yet?
Bill Engeler is offline   Reply With Quote
Old April 20th, 2010, 12:56 PM   #10
Have not found an answer yet to why the fields are all muddled up.
I am still exporting to lower field and if that is the way to solve the issue, so be it.
But it still does not feel right...
Ann Bens is offline   Reply
