First Light Request - HOLD KEYFRAMES, Screen Captures at DVinfo.net
CineForm Software Showcase
Old December 8th, 2010, 05:37 PM   #1
Re-visiting this idea:
1. A toggle to either add a 'hold' keyframe so the color correction does not animate between keyframes. User could select to drop either an 'animated keyframe' or a 'hold keyframe'.
2. A button to do screen captures at the resolution of the image. These could easily be emailed to the client for approval without having to go into the NLE to export the frame. This would be handy.
3. Option to apply a look before white balance / primary color correction.
Thanks Guys!
Great work... as always!
Justin Lovell
cinematographer//8mm.16mm>HD.transfers . www.framediscreet.com
Justin Lovell is offline   Reply
