5D Mk2 Render to Self Contained Quicktime at DVinfo.net
CineForm Software Showcase
Old June 8th, 2011, 09:58 AM   #1
I'm usually using a workflow which takes a 5D Mk2 MOV file and uses Cineform to convert to an AVI. I then edit and either render to BluRay or render to a MP4 file for upload to Vimeo or YouTube. Considering entering a 48HR and they require a "self contained Quicktime file".
Is there a render from Vegas Pro to this? and what properties are common? Leave at 1920x1080 30p or does it need to be converted to another format?
I'm using Pro 10.0d on Windows 7 box.
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom
Harry Simpson is offline   Reply With Quote
Old June 8th, 2011, 10:14 AM   #2
CTO, CineForm Inc.
Re: 5D Mk2 Render to Self Contained Quicktime
I'm very experienced with the 48 Hour Film Project, entered it eight times, and done the HD projection for San Diego for the last for years. Those submission requirements are to preventing you making a reference movie (where the real media is left on you hard drive.) All quicktime exports from Vegas will be self contained. You should contact the local 48Hr producer as submission requirement can be different for cities projecting in HD. In San Diego we distinctly prefer not to have a DVD or a Quicktime file "with no proprietary codecs" so we want it to look good, therefor CineForm files or ProRES in a pinch.
Old June 8th, 2011, 11:26 AM   #3
David,
That is their requirement - so would Cineform transform for editing sake and then render back out to a MOV be legal? Is Cineform transfer if later rendered considered a proprietory codec??
Old June 8th, 2011, 11:46 AM   #4
CTO, CineForm Inc.
As I point out their requirement might be wrong for your city. All they typically want is SD DV, yuck! It doesn't matter what you edit with, as long as they can playback the result (why you should check.) If you submit a DV encoded self contained MOV, yet they are projecting HD, you will be kicking yourself.
Old June 8th, 2011, 01:24 PM   #5
I've checked and this is it for the Nashville 48hr:
(preferred) a self-contained Quicktime file with no proprietary codecs on either:
- a data DVD, or
- a USB flash drive
-or-
miniDV
-or-
playable DVD
miniDV and playable (SD as you point out) DVD are out
So I'll probably try to opt for the
- a data DVD
Old June 8th, 2011, 03:43 PM   #6
CTO, CineForm Inc.
That what the web-site says, it is boiler-plate, you need to check if your producer is HD capable -- unfortunately not many cities are. In San Diego we give completely different instruction to was the web says to do.
Old June 8th, 2011, 07:40 PM   #7
Now i'm understanding...email sent.....no response yet.
