cineform and hrx for grading at DVinfo.net
CineForm Software Showcase
Old July 18th, 2011, 01:31 PM   #1
hello,
i have some epic footage that I need to color correct. I would like to know the best worflow. Unforortunatly my Color correction software doesn't support hdrx epic files. It works with cineform raw files.the only problem I have is: if I convert to cinefrom raw via script, the output file doesn't keep extra hdrx informations, I was wondering if there is a way to keep this information so I can use for example in first light, or if there is a way to convert the 2 streams of the r3d hrx file in 2 separate files. thank you so much.
also is there a way to convert to cineform raw and scale the resolution down? I don't need more than 3k resolution but my files are all 5k...Thank you
Matero Materassi is offline   Reply
