New Windows betas for NeoScene, Neo & Neo3D: Build 5.5.4.332, released 12-August-2011 - Page 2 at DVinfo.net
CineForm Software Showcase
Old August 30th, 2011, 09:50 AM   #16
Re: New Windows betas for NeoScene, Neo & Neo3D: Build 5.5.4.332, released 12-August-
Title updated with build and date.
Pete Bauer
Old August 30th, 2011, 02:12 PM   #17
When adjusting zoom, offset x and y, no changes take effect.
We're using Neo on Windows 7 64bit.
Justin Lovell
cinematographer//8mm.16mm>HD.transfers . www.framediscreet.com
Justin Lovell is offline   Reply With Quote
Old August 30th, 2011, 02:29 PM   #18
CTO, CineForm Inc.
Not a bug in general, so ask support.
Old August 31st, 2011, 12:28 AM   #19
I have encountered the same problem. I had cropped a project shot in HD to a 4:3 format. Now I want to remove the crop, looks great in First Light, but in PP5 the crop doesn't away. If its not a general bug, I'll file a ticket.
Carlos
Carlos Bustamante is offline   Reply With Quote
Old August 31st, 2011, 12:36 AM   #20
CTO, CineForm Inc.
Sounds like Premiere is cache frames -- changing the playback resolution normally flushes cached frames.
Old August 31st, 2011, 07:30 AM   #21
Editing Mode Could Not Be Loaded
Using the new builds, when I open existing projects that had a Cineform sequence, I get the following message:
"The editing mode used by this sequence could not be loaded. The sequence will be opened in Desktop mode."
Is this a problem?
Does it matter what mode the sequence is? I have some projects where I have used different presets for the same type of Cineform files (Cineform, DSLR, AVCHD - this is what Premiere chooses when I drag a clip to the new sequence icon) and they all seem to work.
Lloyd
Lloyd Coleman is offline   Reply With Quote
Old August 31st, 2011, 01:47 PM   #22
Transcoded with MVC2AVI m2ts (from Sony TD10E 3D PAL camcorder) instead of 25 fps is 29,97 fps.
This is bug of DS Cineform codec? Because if used VFW version of CFHD no problem with 25 fps.
Serge Victorovich is offline   Reply With Quote
Old September 2nd, 2011, 04:38 PM   #23
I just updated to the latest BlackMagic Intensity Pro drivers (8.5 dated 8/29/11) and the card no longer shows up as a capture device. Uninstalled Neo and re-installed but it still doesn't show up.
Joe Pasarela is offline   Reply With Quote
Old September 2nd, 2011, 04:49 PM   #24
CTO, CineForm Inc.
Install older BlackMagic drivers as that should not happen.
