Weird 3D problem with CF 2D files at DVinfo.net
CineForm Software Showcase
Old December 19th, 2012, 02:32 PM   #1
Contributor
I am a registered user of Cineform Prospect HD, but also purchased a 3D Asus laptop for use with my GoPro 3D camera setup and its 3D software application. When using this laptop for editing of "normal" 2D CF files, they are all imported into my Adobe products as side-by-side 3D files - and also show-up that way in Windows Explorer.
My 3D laptop does not have Prospect HD on it, but does have the CF 3D software. Is that causing the problem, and if so, is there a way to stop it?
Thanks.
Stuart Brontman is offline   Reply With Quote
Old January 10th, 2013, 12:14 PM   #2
Sponsor: CineForm
Re: Weird 3D problem with CF 2D files
This is just a playback mode. You can change it back to 'left eye' by using the CineForm icon in the Windows taskbar. Right click on the red letter 'C' next to your system clock in the taskbar and then in the 3D Display Type, select 'Left Eye'. Then your 2D files will play in 2D.
Jake Segraves is offline   Reply
