-   CineForm Software Showcase (https://www.dvinfo.net/forum/cineform-software-showcase/)
-   -   what size should the video be? (https://www.dvinfo.net/forum/cineform-software-showcase/54844-what-size-should-video.html)
Jim Rog November 22nd, 2005 09:08 PM
Hello
Why is it that CineForm puts all the files into individual files when capturing the video? is there any way to capture the whole video as one file in HDLink? Also what should the size be for 21 mins of video? Mine has turned out to be just under 14GB is this correct? is there any way you can change the settings in CineForm HDLink so it takes up less space?
Steven Gotz November 22nd, 2005 10:39 PM
Because you told it to "scene detect" which is a good idea, otherwise the audio loses sync with the video when you try to capture it all at once.
The medium setting takes about 40GB per hour.
If you can't handle large files, you should not be editing HDV. I am sorry, but HDV requires massive storage and all the power of a PC you can through at it.
Dave Campbell December 3rd, 2005 06:26 PM
Steven, I tried scene detect once on an hour tape. The darn thing made 200 files so I said forget that. Now, David, is their lip sync issues with the cineform s/w as one big file capture? Man, I hope not since I am putting in 4 hours worth of tapes in single huge files for the 5th time.
dave
David Newman December 4th, 2005 08:48 PM
There are sync issues with HDV if you don't break the scenes. The MPEG scene break make different length of video and audio at the boundary points. Using scene breaking solves this.
Dave Campbell December 5th, 2005 07:59 AM
Wow, where is this documented? I keep finding more and more issues with HDV that do not seem to be well known from all the stuff I have been reading.
So, what are the options? When I did scene break, it chopped my video into WAY to many segments. Now, if it cut them everytime I stopped and started the camera, that may be okay.
So, again, am sitting here pretty shocked with all this stuff. With DV, I just edited. I have already pulled in 4 hours of video 5 times thinking I knew the best way to edit.
So, since scene break does not work well in my experience, David, how do you suggest this sync issue is resolved? Can one do 20 minutes of video via in/out points?
I have to be honest that I have more than once thought that HDV is not worth the hassle. How is gets soft on pans is something that just about has driven me back to DV.
So, is there any format that does not have all these little corner case issues?
Dave
David Newman December 5th, 2005 11:03 AM
You have others issues if the scene breaks are occuring randomly. The scene breaking code works well, most customers love it, so I was surprised at you comments. I don't know the details for the solution, so file a trouble ticket on the support site so that the tech guys can advise you.
Dave Campbell December 5th, 2005 12:08 PM
Okay, will file a ticket.
My first comment is the audio sync issue. I had never heard of this before.
Now, since I never had used scene detection, I had no idea what to expect.
I did not look that closely at the breaks, but when I saw a 1 hour tape was heading over 200 clips, I said heck this that.
Dave
Dave Campbell December 5th, 2005 03:27 PM
Steven, exactly how does one verify if one has the audio sync issue? Should I just go to the end of my 1 hour avi capture, watch on the timeline, and see if I notice an audio sync issue?
Dave
Dave Campbell December 5th, 2005 06:38 PM
Well, I went back and looked at my files I pulled in and yes, by the end they have audio sync issues. Amazing.
So, with all the new settings that I have been trying, I am now for the 6th time trying to bring the clips in with scene detect on and see how many files it makes. So far it seems on one tape to be working better.
Dave
Steven Gotz December 6th, 2005 10:37 PM
Yes, you could get hundreds of files. But, so what? Really. Does it matter?
If the software detects that you shoot a bunch of 10 second clips, is that bad?
Now, if in fact you are shooting continuously and it is not detecting that, then you should work with the Cineform folks for sure.
For me, the scene detect seems to get me to the right spot vi=rtually every time, so it never mattered to me. It gives me a chance to review each clip, and then name the clips before I use them. I still use a numbering system, but I add additional text to the names quite often.
Dave Campbell December 6th, 2005 10:57 PM
Steven, if one does 10 second clips, I agree. I do not know what happened the first time I tried, because I have redid them all again, and on the first tape, each break was a start record spot, and it can not do any better than that.
Dave
Steven Gotz December 7th, 2005 09:45 AM
Glad to hear that you got it working.
Marc Colemont December 9th, 2005 04:14 AM
Dave, I couldn't work anymore without scene detection.
It makes life so easy during editing.
- Each scene you shot is nicely made as a file. So no time to waist finding in the in/out points.
- in premiere as soon as you used the clip it is marked. So no accedental double use of a scene unless you want.
- it is easy that way quickly remove bad scenes, and to be able to filter that way all your scenes.
- you can group scenes in catagories. so all close-ups, wide shots etc are nicely available when I edit video, without the need to look in a very long file for the right scene all the time.
Dave Campbell December 9th, 2005 08:23 AM
Marc, now that I have used it again, I totally agree with you!
Its just that this audio problem is not well known. I just told a friend of mine last night who does lots of editing and he had never read about the issue. I have never read about it in any editing magazine I get. Is this an industry secret?
This is what makes the internet forums so great. The ability to share knowledge!!
Dave
Pierre Barberis December 11th, 2005 12:50 PM
David, Please, de-couple "Split scenes" for M2Ts and AVIs
I posted this as a wish a few versions ago. And you at Cineform answered that it was a sound suggestion.
To day you have only one choice, if you want do to it one pass: either you split AVIs AND M2Ts or NONE of them. Very often what makes sense is to capture the M2Ts as a whole And Split scenes for the CFHD AVIs only. Much easier to work with, much easier to archive, etc...
This would require FOUR lines of code at most and ONE extra control in the preferences panel. Please, do it !!!
Patricia Lamm December 16th, 2005 10:32 AM
Is this audio sync only an issue when capturing with HDLink? Does the same problem occur when capturing using Aspect HD from within Premiere Pro (i.e., batch capture in PP with scene detect unchecked)? I guess my question is, when capturing from within PP, is it best to always check 'scene detect'?
David Newman December 16th, 2005 10:51 AM
It is best to use scene detection, yes. You can turn scene detection off when re-batch capturing without issue (assuming your batches don't cross a lot of scene boundaries.)
Patricia Lamm December 16th, 2005 11:03 AM
Thanks, David. I just turned on scene detection in PP for an HD capture (using batch) but don't see any evidence that it worked. I tried this with a tape that has several obvious camera stops/starts. Should i see different AVI files? (I don't -- it's just one long file.) There's no evidence of different scenes within PP either.
David Newman December 16th, 2005 11:13 AM
I guess batch superceeds scene detection.
Patricia Lamm December 16th, 2005 11:23 AM
Strange. I have scene detection selected within batch. Are you saying that it's possible that batch + scene detection = batch + no scene detection (in reality)?
I'm not seeing any audio sync issues with this tape, even at the end, but given what I've heard about audio sync problems for other people I'm hesitant to make this my standard workflow.
So I guess the bottom line is: no batch capture in PP with AspectHD because the scene detect doesn't work?
Dave Campbell December 16th, 2005 11:40 AM
What are you using batch for?
I just read my entire tape(s) with scene detect on.
Or, I start it at an in point/out point if I do not want the entire tape, but have multiple scenes
Dave
Patricia Lamm December 16th, 2005 12:05 PM
Dave, I have always used batch in the past so that the capture would be repeatable (after deleting the main captured file, for example). It's a pretty useful tool.
I just tried record + scene detect and it worked fine (detected scenes). I could not get 'in/out' capture + scene detect to work however. It just hung while in 'seek' mode. (My in/out points were set correctly.)
Dave Campbell December 16th, 2005 12:09 PM
I had to recapture a tape the other night and the scene capture seemed to been frame repeatable.
I used in/out with scene detect 2 nights ago and it worked great for me.
Dont you love all these differences. :o)
Dave
Patricia Lamm December 16th, 2005 12:19 PM
Not!
