Scene Selection at DVinfo.net
CineForm Software Showcase
Old May 16th, 2006, 11:21 PM   #1
Scene Selection
I'm having problems with PPro 2 DVD Layout and Scene Selection. The clips are XL H1 30f m2t files converted to CFHD avi files. Just thought I should check, do CFHD clips work with Scene Selection? Any known problems?
Best,
Christopher
Christopher Glaeser is offline   Reply With Quote
Old May 17th, 2006, 10:57 AM   #2
I solved part of the problem by reducing the number of scenes. The DVD menu now navigates fine, but the images in the scene selection are blank white.
Best,
Christopher
Old May 19th, 2006, 01:36 PM   #3
Sponsor: CineForm
CineForm products do not currently support the DVD Layout function in Premiere Pro 2.0. It is however something we will consider implementing in a future release.
As a workaround, you can make a New Project with the same frame rate and resolution settings, but choose 'Desktop' as the Editing mode in your General Settings. Then import your original project into this one and load the DVD Layout pane. You should now be able to preview and build your DVD properly.
Jake Segraves is offline   Reply
