Does NEO support the new Intensity Pro board?
David, will the new codecs function okay with the Intensity Pro board, with both analog and HDMI inputs?
Does Aspect HD for Premiere Pro (Win XP) allow you to export your timeline to a .mov Cineform HD file?
Aspect HD v5 will.
I downloaded the trial version of Aspect HD a few days ago, however I ran into an error when trying to use Sorenson Squeeze (latest version) with the Cineform .avi file. I contacted Sorenson, and they said that Squeeze does not support Cineform files. This is a downer, because that was the exact workflow I was hoping to achieve, since I need to encode all my videos for the web using Sorenson Squeeze. I think I heard that Squeeze will accept the .mov Cineform files... is this correct? If so, is there any difference between the .mov and .avi Cineform files? Size, quality, etc? Thanks David. |
Thanks for the info David... does Squeeze have any problems with the .mov Cineform files? I'm really looking for a way to make this all work.
None that we have found. The fault with Sequence is not with the compression but with the file wrapper, so while AVI doesn't work in their product the MOV of the same data does.
And the ability for me to use the .mov files will be available in Aspect HD v5? If I ordered v4 in the meantime, is there a free upgrade to v5? Thanks for your help. |
Deke,
Yes new orders of V4 will get V5 upgrade for free. |
I may not be looking carefully enough, but for a little while I thought I'd gotten the impression that Cineform (on PC) supported a QuickTime wrapper as well, but with applications that load AVI via QT, the frame comes up blank (no codec). This is Aspect HD, latest version.
Today's Prospect HD/2K supports quicktime on the PC, Aspect HD v4 does not. Aspect HD v5, out at the end of the month does.
Thanks, David.
I'm pretty sure you replied even before I hit Post. A little spooky, that. |
David, is NEO HD not available for (beta) download yet? I tried to download the trial (from the link that says all betas available for Windows) from the Cineform's NEO page but the link I get sent is for Connect HD 3.41.
NEO HD Support
can we open a CF NEO HD template for editing those videos in Vegas8? or better go with CS3 & Propspect 2k for YUV10bit 422 videos? |
I have what might be a stupid question, but is there any way to use NEO HDV on the MAC platform?
I do event video shooting with Sony FX1's and work in both Sony Vegas and FCP on a quad core MAC PRO system, and have no need of 10-bit HD footage, as 8-bit is fine for my purposes. Would I need to purchase NEOHD and capture in a lower 8-bit format, or is there a way that I can use NEOHDV on a MAC. I'm weighing y options on work flow using FCP and either capture in ProRes 8-bit, capture and work in HDV and QT export to ProRes, or use Cineform 8-bit and render out as either Cineform or ProRes. |
But if I decided that I wanted to encode as ProRes from FCP, I could use NEO HDV for capture on the PC side sing Bootcamp or Parallels, correct? |
Michael, yes, you can use Neo HDV (Windows) for capture/inv telecine/etc on Windows and produce a CineForm MOV file. That CineForm MOV file can be directly imported into FCP. On Mac, if you don't intend to render back into CineForm files - i.e., all Mac renders will be to ProRes - then you can use CineForm's free Neo Player-Mac. If you want to render into CineForm files on Mac then you'll need Neo HD which comes with serial numbers for both Windows and Mac.
NOTE1: Because we don't yet have HD Link running on Mac we temporarily offer both Windows and Mac S/Ns with a purchase of Neo HD. Hopefully we'll have our first look at HD Link (will be renamed) on Mac in early/mid 4Q. NOTE2: Parallels previously didn't properly support Firewire ports, although I know that was a bug they were going to fix. You might double-check this. This is relevant for HDV capture using Parallels. Bootcamp works fine. |
| All times are GMT -6. The time now is 03:10 PM. |
