Video Streams Question at DVinfo.net
CineForm Software Showcase
Old May 13th, 2007, 08:10 PM   #1
I inadvertently posted this in the "General DV Acquisition" forum and it's still there. Apologies for the double posting.
In the Cineform literature (website) regarding Aspect it talks about supporting multiple (up to 4?) video streams, yada, yada.
What is a video stream? I'm guessing it would be the clip(s) on one video track in a sequence/timeline? Does the term also include the audio track in the "stream"? If the logic is correct, then 4 video streams would be the clips on four video tracks in the same timeline/sequence?
Dearl Golden is offline   Reply With Quote
Old May 13th, 2007, 11:04 PM   #2
Yes. Of course performance can vary based on your hardware environment. But on a modern CPU plus a two-drive RAID 0 you should easily get 4+ HD streams on a Premiere Pro timeline with Aspect HD.
David Taylor is offline   Reply With Quote
Old May 14th, 2007, 07:19 AM   #3
Thank you, David.
