Fusion at DVinfo.net
CineForm Software Showcase
Old June 8th, 2007, 06:20 PM   #1
Fusion
David,
Looks like you have tweaked the dshow import of CineForm avi in fusion with .130?
Salah Baker is offline   Reply With Quote
Old June 8th, 2007, 07:43 PM   #2
int16 seems to SmR
Old June 8th, 2007, 07:58 PM   #3
CTO, CineForm Inc.
We haven't change anything in particular for Fusion, so how do you mean?
Old June 8th, 2007, 08:34 PM   #4
will go ticket ...seems whatever changes you did fusion sees CF avis in a differing light
Old June 9th, 2007, 08:51 AM   #5
sees the CF avis as a qtime file now in loaders on import
Old June 10th, 2007, 06:49 PM   #6
Fusion seems to do this. Sometimes the (proper) AVI loader gets used; other times it seems to fail and kicks down to the QT loader (which if you have Aspect HD means it doesn't work, since there's no QT CFHD codec).
This is predictable and file-dependent (i.e., it's replicable for a given AVI file). I communicated back and forth with Fusion support on this, but as far as I know it didn't get resolved. Hey, not everyone can be Cineform support...
K. Tessman is offline   Reply With Quote
Old June 10th, 2007, 09:56 PM   #7
CTO, CineForm Inc.
One correctly, Aspect HD v5.0 now has a QT codec, so it is also likely to work with Fusion now.
Old June 16th, 2007, 09:36 AM   #8
Is the Windows QT codec on par quality/performance-wise with the AVI codec? (I'm guessing yes, or close-to-yes?)
If you remove the QT loader from its folder, Fusion will load all CFHD AVIs properly. So regardless, this is still Fusion being twitchy, it seems (unless Cineform is doing something suspect that leads to the AVIs being misidentified). It's the only application I've seen do this.
Old June 16th, 2007, 09:47 AM   #9
The visual quality is identical - just a different wrapper. Using our HDLink utility you can also re-wrap one to another if an application has a specific preference. To re-wrap AVI to MOV, just select MOV as the output format. As long as no other conversion options are checked an identical file is created with a MOV wrapper without touching the underlying compression. It's almost as fast as a file copy.
David Taylor is offline   Reply
