Encoding Issue - Really frustraing at DVinfo.net
CineForm Software Showcase
Old July 23rd, 2007, 12:51 PM   #1
So I'm done capturing 10 minutes of footage from the canon hv20 and press 'stop' it says one moment please encoding footage.
And nothing happens. Nothing at all. It just freezes.
I have a good PC, I have updated windows. Why??
Joseph Kassana is offline   Reply With Quote
Old July 23rd, 2007, 02:42 PM   #2
I have had that happen. When you close HDLink, did you check to see if the file was there?
Try capturing just the MPEG file and convert in a second step. Does that work?
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old July 24th, 2007, 02:05 AM   #3
Nope, nada don't work. BAdly frsutrating.
Old July 24th, 2007, 03:38 AM   #4
Images: 1
Submit a trouble ticket to cineform.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old July 24th, 2007, 07:03 AM   #5
When I first installed Cineform, I had a similar issue. Cineform would freeze during capture using firewire. I tried rebooting and check connection, still NG.
I ended up uninstalling Cineform and reinstalling and it worked.
Old July 24th, 2007, 07:37 AM   #6
Try using the free utility HDVSplit. If that works to give you M2T files, use HDLink to convert them to Cineform. If that works, at least you have a workaround until you get it figured out.
Steven Gotz
Old July 24th, 2007, 08:53 AM   #7
CTO, CineForm Inc.
As Steven Thomas discovered, sometimes it is just an install issue. If you can't capture M2T files, something is very wrong. Please try an uninstall and a re-install.
Old July 26th, 2007, 09:53 AM   #8
Will try this. Don't I loose my activation when I uninstall?
Old July 26th, 2007, 10:34 AM   #9
No, your activation will still be on the computer unless you take specific steps to de-activate.
Pete Bauer
Pete Bauer is offline   Reply
